Tire Question: Mixing Radial and Bias ply Tires?
- 79MKII
- Love Them Kaws!
18 Jan 2014 16:52
I am seeing more and more motorcycles with a sportbike rear wheel and radial tire being run with a standard size, bias ply front tire. I have always been told that radial and bias ply cannot be mixed or very poor handling can occur. I have felt this on a car, btw. I think I had radials in the rear and bias ply on the front.
Does anybody have first hand experience with mixing tire types? I'd love to hear some real world information about this. I'm considering going with a more narrow dragbike style front wheel on my MKII but have a 180mm rear radial. They don't make super wide bias ply tires and you can't get skinny radials.....so what do you do?
Thanks
Thanks
The Kaw List:
Re: Tire Question: Mixing Radial and Bias ply Tires?
18 Jan 2014 17:16
I don't have any experience mixing radials with bias tires, but if you use the bike on the street I would be very careful about installing a skinny front tire. It may have a detrimental effect on handling whether or not it is bias or radial, but more important regardless of the tire's construction if it is very narrow it will affect your ability to stop the bike quickly. During hard stops, 75 - 80% of the bike's braking is done by the front brake because of the weight transfer from rear to front. So with a narrow front tire the front is much more likely to skid in an emergency braking situation. It's definitely something to consider since it bumps up the risk factor of street riding. Ed
- kzz1king
18 Jan 2014 17:29
I have mixed them up on my Kawi Concours as have many other Concourse owners.
Wayne
Wayne
Home built KZ1000 turbo setup
- 79MKII
- Love Them Kaws!
18 Jan 2014 17:36
Yes, great things to consider. I should have been more clear but what I meant was a standard size tire....maybe a 90/90 or 100/90. Skinny compared to modern sportbike rubber. There are no radials that will fit on a 1'.85" or 2.15" rim, so if you go with a fat rear tire, you have to change your front wheel to allow for a wider radial on the front too.
So the ultimate question I'm getting to is, "if you put a wide rear tire on your kz (160mm or wider), do you have to change your front wheel? If not, you have to mix radial and bias ply...is that OK?
The Kaw List:
- 79MKII
- Love Them Kaws!
18 Jan 2014 17:38Good to know, thanks. Why is it that they end up mixed on the Concours?kzz1king wrote: I have mixed them up on my Kawi Concours as have many other Concourse owners.
Wayne
The Kaw List:
- Powerstroke_fan
18 Jan 2014 18:43
Not sure but iam running a 190 rear tire off a hayabusa with a stock size front tire and rim. I havent noticed any problems. i dont see why it would cause any problems.
1977 KZ 1000 work in progress
- bountyhunter
18 Jan 2014 21:32
I thought the big taboo was mixing them on the same set of wheels on a car (front or rear) but I thought it was OK as long as the front had both the same and the rear had both the same. YMMV
- kzz1king
19 Jan 2014 17:57
No, not mixed stock. Guys on the forums are mixing them and I have as well.
Wayne
Wayne
79MKII wrote:Good to know, thanks. Why is it that they end up mixed on the Concours?kzz1king wrote: I have mixed them up on my Kawi Concours as have many other Concourse owners.
Wayne
