Rear Wheel Play
  • grumpy56
  • grumpy56's Avatar Topic Author
Rear Wheel Play
18 Jan 2014 15:08
#619088
1982 KZ1000J, mag wheels. I have side-to-side play in my rear wheel. Can't tell how much, but my guess is it would be .010-.020". When I spin the wheel, at one point there is no play, but as I get to a certain point, then I have the side-to-side movement. It seems to be progressive, increasing from zero to maximum back to zero with a full spin of the wheel. Any ideas? Thanks.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
  • steell
  • steell's Avatar
Re: Rear Wheel Play
18 Jan 2014 15:24
#619091
I'd check the rear wheel bearings, and then replace them anyway cause they are cheap. Unless you go with ceramic bearings, then they are around $350 or so :ohmy:
  • dkoz
  • dkoz's Avatar
Re: Rear Wheel Play
19 Jan 2014 17:45
#619220
steell wrote: I'd check the rear wheel bearings, and then replace them anyway cause they are cheap. Unless you go with ceramic bearings, then they are around $350 or so :ohmy:
might as well check the swingarm while your at it
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
  • grumpy56
Re: Rear Wheel Play
22 Jan 2014 17:28
#619685
Thanks for the replies. Will replace the bearings and at least check the swing arm bearing when I change the rear tire.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
Re: Rear Wheel Play
22 Jan 2014 17:37 - 23 Jan 2014 19:23
#619687
When you pull the rear tire if you unbolt the shocks at the swingarm, grasp the ends of the swingarm, and try to twist it you may be able to detect if there is any play in the swingarm bearings. When my swingarm bushings needed to be replaced I could feel play there when I tried to twist it; after replacing the bushings there was no twist. Ed
Last edit: 23 Jan 2014 19:23 by 650ed.
