Frame slugs, and 1" MS tubing
- jp-15
15 Jan 2014 21:42
Anybody know where I can find these items online? I tried a search, but came up empty. I need to replace a couple bars on a frame. Looking for advice on thickness, and slugs to go with this tubing.
Thanks,
Joe Phillips
Thanks,
Joe Phillips
1976 bobber KZ900
903cc
K&N Pods
4-1 V&H
VM26's
Dynatek S w/Green Coils.
Winter Project= 10.25:1 1015 cc kit w/ Web cams and Refurbished head. 33 smoothies hopefully.
903cc
K&N Pods
4-1 V&H
VM26's
- wireman
Re: Frame slugs, and 1" MS tubing
16 Jan 2014 13:46
Any decent machine shop or welding shop should be able to make you up some slugs on a lathe.
17 Jan 2014 06:57
speedymetals.com
or
shapirosupply.com/
are good places to source the tubing unless you are looking for metric od's.
i would try to use as close to the same o.d. as the tubing you are replacing and a .120 wall in dom will be completely sufficient.
if you can buy tubing the same wall thickness,and the same od as the id of the tube your replacing you can cut it down and use it for slugs.
hth,
or
shapirosupply.com/
hth,
