I found some LTD airshocks. Whats the reason for
  • HAFROD
  • HAFROD's Avatar Topic Author
15 Jan 2014 12:15
#618723
Guys, I found some airshocks off an LTD. I believe they are stock. What would be the reason for having airshocks on your bike? Heavy passengers? Maybe adjustable ride height?
Two 1983 GPz 305's, 1984 GPz550, 1980 KZ550A, 1978 KZ1000A2A
  • Cynjut
  • Cynjut's Avatar
Re: I found some LTD airshocks. Whats the reason for
15 Jan 2014 13:29
#618738
The 'standard' adjustment for shocks is to change the spring pre-load. Air shocks give you that capability without having to change anything physical on the bike.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
  • HAFROD
15 Jan 2014 17:05
#618767
Any idea on how much travel they give? My idea is to use them for ride height adjustments.
  • nivlac
  • nivlac's Avatar
16 Jan 2014 21:14
#618908
I put a set on my LTD and don't notice any measurable height change.
1983 kz1100
1979 cb650
  • koolaid_kid
  • koolaid_kid's Avatar
17 Jan 2014 06:22
#618934
They are really intended just for preload sag, so you can vary the amount of pressure depending on how much weight is on the bike. For example, you would increase the pressure if you had a passenger, or decrease it for riding solo.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • z1kzonly
  • z1kzonly's Avatar
17 Jan 2014 11:35
#618968
I would go with the weight issue! :woohoo: :laugh:
  • sbc1320
  • sbc1320's Avatar
17 Jan 2014 11:58
#618973
z1kzonly wrote: I would go with the weight issue! :woohoo: :laugh:
Might need a set of helper springs in that case or either double up on the air shocks. :( :( :(
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
