Front fork question?
- sbc1320
04 Jan 2014 08:26 - 04 Jan 2014 11:28
Got it already, needed right size bolt down inside fork housing.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
Last edit: 04 Jan 2014 11:28 by sbc1320.
- 4TheKZ1000
Re: Front fork question?
04 Jan 2014 16:09
I looked all over and couldn't find the thread pitch. Its an 8mm but no pitch.
I do know its a very fine thread pitch though.
- sbc1320
04 Jan 2014 16:25 - 04 Jan 2014 16:26
I had read somewhere a good while back to use a 7/16"( I think) bolt and nut which will be a 3/4" head. I had welded a nut and bolt together at work months back and had it with my KZ stuff. Turned out it was too big, had to go with a 17 mm metric bolt head and nut. Pitch doesn't matter as you are just making a tool to hold the plunger from spinning while taking an 8mm allen wrench to the bottom bolt of the forks.
Anyways I clamped the fork housing down to my steel table, slid a medium size chisel from my chisel set down the tube and held it with an extension and 3/8" drive ratchet and I think it was a 5/8"(size of chisel) socket. Worked perfectly to get them apart then I was able to get the17 mm head for a bolt and nut at the auto parts to tighten it back up. Monday I will weld up the bolt and nut so I can use it to take the next ones apart someday. I did use it to tighten them back up, but you can't take it apart with this unless you weld the nut or double nut, even could use a left handed nut and bolt. Anyways finished and even did a quick polish job to the lower housings and managed to put a few miles on her also today. No more forks leaking the oil and I installed 2 new OEM fork tubes also.
Last edit: 04 Jan 2014 16:26 by sbc1320.
- sbc1320
04 Jan 2014 16:284TheKZ1000 wrote: I looked all over and couldn't find the thread pitch. Its an 8mm but no pitch.
I had that end covered, but the plunger was spinning inside the fork tubes. Had to figure out how to hold it, get it apart and find out what size I need to put back and for any next times also.
- 4TheKZ1000
04 Jan 2014 16:35 - 04 Jan 2014 16:46
My manual says:
" front fork bottom Allen bolts" - " 10 mm Pitch 1.25 "
the part number shows a 8 mm Allen.........shit I don't know.
:huh:
:huh:
Last edit: 04 Jan 2014 16:46 by 4TheKZ1000.
- sbc1320
04 Jan 2014 16:42 - 04 Jan 2014 16:424TheKZ1000 wrote: My manual says:
" front fork bottom Allen bolts" - " 10mm Pitch 1.25 "
I was talking about the plunger holding tool size for inside the fork tubes for rebuilding my front forks. I got it though already and have it all shined up. Thanks though.
Last edit: 04 Jan 2014 16:42 by sbc1320.
