Frame tube thickness
  • kaw-a-holic
  • kaw-a-holic's Avatar Topic Author
29 Dec 2013 22:00
#616685
Does anyone know how think the steel is on the chassis of a 77 KZ1000? I'm going to start bracing the frame and have decided to braze them in. I don't have a TIG nor do I know how to use them. I like the idea of brazing anyway. It has been a while though so I want to practice on something that is NOT my bike.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • Haybus
  • Haybus's Avatar
  • Big Al
Re: Frame tube thickness
29 Dec 2013 22:48
#616693
IIRC the down tube I sectioned for repair on my frame was 0.095". Brazing can be a tricky art. Cleanliness is very critical.
Alan
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
The following user(s) said Thank You: saxjonz, kaw-a-holic
  • kaw-a-holic
30 Dec 2013 04:04
#616700
Haybus wrote: IIRC the down tube I sectioned for repair on my frame was 0.095". Brazing can be a tricky art. Cleanliness is very critical.
Alan
Thank you Alan. I will make sure to have the surfaces prepped properly. I know a lot of MIG but its my understanding that it can make the frame brittle at the weld location. My brother has this pistol grip torch that has a very small focused flame that will work perfect to braze this project.
Jon
1977 KZ1000a1
Mesa, AZ
  • Mercury Kid
  • Mercury Kid's Avatar
30 Dec 2013 05:51
#616708
14ga tubing should be what you're looking for.
'76 KZ900-Z1 clone
Z1 70's period longbike
The following user(s) said Thank You: kaw-a-holic
  • floivanus
  • floivanus's Avatar
30 Dec 2013 15:10
#616778
I thought the brittleness was from trying to mig to dissimilar metals, say a cro-moly brace to a mild steel tube? Correct me if I'm wrong
Past; 78 kz1000, 83 kz550
Andrew
  • kaw-a-holic
30 Dec 2013 20:10
#616809
I'm not sure about that. Hoping someone will speak up. I was planning on using cold rolled steel for the braces unless someone corrects me.
Jon
1977 KZ1000a1
Mesa, AZ
  • Shdwdrgn
  • Shdwdrgn's Avatar
30 Dec 2013 21:03
#616812
Is brazing really suitable for this? Sorry, my only experience was with trying to repair a bicycle frame, and the brass came apart within a couple of days. I can't imagine it would do well with the vibrations of a motorcycle? However I also know now that brass will harden when allowed to cool slowly, which is the opposite of steel. Maybe it needs to be properly tempered in order to survive the conditions?
I welded my kz frame with a mig. For the projects I do, I only use mild steel wire which does not air-harden like some types of welding rod will do. I suppose I should weld up a test piece with some scrap frame tubing and beat it with a hammer to see how tough the weld really is. From what I could tell when I was chopping up the donor frame (and I am by no means an 'expert' on this) the original frame looked like any standard hot-rolled mild steel.
1981 KZ1000-JK1
She's a beautiful mess, and I've made her all mine
  • kaw-a-holic
30 Dec 2013 21:08
#616814
I have seen pictures of the Sanctuary boys brazing them in. Here is some info I found from Leon(Black Banshee)
Great thread 531. I like the gussets you build. I don't see a problem with an extrusion in the front frame braces. Saves weight, adds strength, and you can paint behind them then.
At the beginning of the thread, there is mention that the Japan guys don't weld to the plates to their frames. I'm thinking they hammer weld(forge)the plates in. Obviously that isn't an option for your average weekend warrior in his home shop.
Tig is by far the best process to weld these braces. Proficient welders can weld with anything, just look at the gasless welds that were pictured a page or two back.
"Good choice on filler rod too Leon. I've known some builders to take a torch and draw the welded areas to around 4-600 degrees to temper the joints. I believe the AWS ER70S-2 filler takes care of any brittle joints created when welding CrMo.
Did I mention I like this thread. :cheer:
Here is a couple good articles on welding CrMo:
www.netwelding.com/Heat_Treated_4130.htm
www.weldingtipsandtricks.com/welding-4130.html "
I would still like to know what you find. My thought was it's pointless to brace if I am going to cause the frame to be brittle at the welds.
Jon
1977 KZ1000a1
Mesa, AZ
  • kaw-a-holic
30 Dec 2013 21:11
#616815
Jon
1977 KZ1000a1
Mesa, AZ
  • zed1015
  • zed1015's Avatar
31 Dec 2013 02:49
#616828
Either fusion welding , brazing or bronze welding your frame will be fine.
It is (hot short) alloy steels i.e Reynolds 531 etc that have to be bronze welded to prevent brittleness and fracturing due to overheating.
If done CORRECTLY the brazed/Bronzed joint is extremely strong , flexible and won't come apart.
Ideal for building entire motorcycle frames.
Here is the Bronze welded suzuki XR69 frame.
[IMG
[IMG
The following user(s) said Thank You: wireman, kaw-a-holic
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
31 Dec 2013 09:39
#616866
Had to log in with my phone to see this for some reason :/.
Sounds like zed got it all squared away tho.
Leon
