Master Cylinder Piston? Disc Pads? Front Forks?
  • TomasDouglas
  • TomasDouglas's Avatar Topic Author
15 Dec 2013 16:32 - 15 Dec 2013 16:40
#615568
I am rebuilding a 1980 KZ550 that sat for 12 years, it has 15,000 km on the speedo. When I opened the master cylinder it was filled with gunk (see pictures) so I cleaned the reservoir but I can't figure out how to get the piston stop ring out (see diagram) it doesn't appear to be a snap ring with loops. I want to get the piston out so that I can check the rubber cups and clean out any gunk. Can anyone help me?
I also took the front brake caliper apart to clean, the disc pads still have 3 mm (inner) 4mm (outer) of wear the manual says replace at 1 mm. Do you think I am ok continuing to use the old pads?
The forks after i cleaned them up look ok the dust covers and seals in good shape no leaks and the forks compress ok and rebound good. I only plan on changing the oil is this ok?
Thanks
Tomas
Attachment Master_Cylinder.JPG not found
Attachment IMG_0237.JPG not found
Attachment IMG_0239.JPG not found
Attachment IMG_0231.JPG not found
Tomas Douglas
1980 KZ 550A
1986 GPZ 550
Last edit: 15 Dec 2013 16:40 by TomasDouglas. Reason: adding pictures
  • TomasDouglas
Re: Master Cylinder Piston? FIXED
17 Dec 2013 19:33
#615772
The piston was only held in by gunk, I soaked it overnight then I used a chopstick from the outlet and pushed gently and the piston came out. The white plastic liner was the only thing holding the piston in.
Now on to replacing oil in the forks.
Tomas
Tomas Douglas
1980 KZ 550A
1986 GPZ 550
