Z1 triple trees
  • floivanus
  • floivanus's Avatar Topic Author
Z1 triple trees
10 Dec 2013 07:00
#615180
What do there things look like? I have kz trees that came on my z1 frame and the headlight fit is tight, the gauges dont mount up and ebay only returns the usual "dragbike kz z1 900 1000" listings instead of what i want to see
Past; 78 kz1000, 83 kz550
Andrew
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Z1 triple trees
10 Dec 2013 07:58
#615184
Obviously this is for a NOS but have a look to spot the gauge mount difference.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • floivanus
Re: Z1 triple trees
10 Dec 2013 09:09
#615190
Whoa, thats more than i have in the whole bike so far (missing a battery box side covers and tail light.) :woohoo: is there a difference in the fork spacing on the z1's? And whatabout the bottom tree?
If z1 parts end up being to much wife may get this thing for a modified bike. And i'll just clone a z1 into one of the 80ltd frames instead :(
Andrew
  • StreetfighterKz
Re: Z1 triple trees
10 Dec 2013 09:16
#615192
I believe that the lowers should be close to the same and fork spacing should be the same as well but I've not had the two apart and in my hands to know for sure.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • floivanus
Re: Z1 triple trees
10 Dec 2013 09:31
#615194
I know one of these bikes (73 Z1 or 78 1000A2) came with a lower tree that was slightly narrower maybe an eighth of an inch or so.
I seen that same seller has a lower tree, simillar to ones i have but it has that boss for an ignition switch i guess?
Andrew
  • z1kzonly
  • z1kzonly's Avatar
Re: Z1 triple trees
10 Dec 2013 18:17
#615247
Ya gotta be more specific? With pictures. Yes the top tree's are different KZ & Z1 only the speedo mount.
Bottom triple tree is the same on all Z1 & KZ900 & KZ1000 except the Z1 bottom has a hole on the right side for the 73-75 sterring stabilizer. The tops are different Z1 has a solid mount for the gauge bracket, 2 - 8mm bolts hold that mount to the bottom of the top tree. Then in 76 Factory went to rubber mounted holes for the gauges. These tops are interchangable. If you need a Z1 top, just wait around for one. Hence you need the gauge setup for that also. They pop up on ebay all the time. I just sold one 3 months ago for $14.99, no one bid on it? Whatever.
So, what do you have?
And what are you using?
KZ guages?
Or Z1 guages?
  • floivanus
Re: Z1 triple trees
10 Dec 2013 20:31
#615253
Bike came with near perfect early z1 gauges and holder.
All the lower triples i have dont have the hole for the steering lock or whatever that is
Andrew
  • z1kzonly
  • z1kzonly's Avatar
Re: Z1 triple trees
11 Dec 2013 09:07
#615282
Your lower tree is a 1980 model, the sterring lock was in the neck of the frame. You will see a rectangular notch cut into the stem. Plenty on ebay, That "oinkjohnson" sells alot of them.
If you can beat his team of shill bidders.
If you want to use your stem, a good machinist can drill the bottom hole out and you can install an old stem lock.
But top 73-75 tree's are pricey.
Sell your Z1 gauges on ebay, you will get some nice money. Then go with KZ style gauges.
  • Z1Driver
  • Z1Driver's Avatar
  • love the smell of triple smoke
Re: Z1 triple trees
18 Dec 2013 15:38
#615851
I would keep looking. The right set will come along.
Blue 1975 Z1B
Red 2009 Concours 14
  • kzz1king
  • kzz1king's Avatar
Re: Z1 triple trees
18 Dec 2013 17:12
#615863
What are you looking for? I am pretty sure I have a front end from my 75 in parts on the shelf.
Wayne
Home built KZ1000 turbo setup
  • floivanus
Re: Z1 triple trees
20 Dec 2013 09:58
#616000
Would just need the trees and all the crap that bolts to them. Got the forks brakes fender and wheel already
Andrew
