rear wheel bolts
  • Schmeck
  • Schmeck's Avatar Topic Author
rear wheel bolts
02 Dec 2013 17:19
#614650
Can anyone tell me the thread size of the bolts for the rear sprocket on a 79 kz750 twin . All my bolts are rusted and cant seem to get an accurate reading at the store for them .
1979 kz750 twin -Soon to be roadworthy
1988 El250 engine in custom hard tail frame - collecting dust
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: rear wheel bolts
02 Dec 2013 19:15 - 02 Dec 2013 19:32
#614662
10 mm bolt x 41 mm length - thread pitch 1.25 mm
Just a guess on thread pitch....watch this some 10 mm go to 1.50 mm pitch but im 90% sure its 1.25 mm.
2 things you can do.
1. use a tap and die pitch gauge to check threads.
2. take bolt and nut with you and see if it will thread on a 10 mm x 1.25 pitch
www.cmsnl.com/kawasaki-1979-kz750-b4_mod...t/57913.html#results
www.partzilla.com/parts/detail/kawasaki/KP-42045-005.html
Last edit: 02 Dec 2013 19:32 by 4TheKZ1000.
  • Schmeck
02 Dec 2013 19:59
#614665
well I took the nuts to a local tractor supply and could swear it was one size that it screwed on to . so i buy 6 , get home and they didnt fit? confused. Will go to a lowes and check the sizes you gave me , thanks
