'83 KZ1000R2 Swing arm bearings not there?
- tommyboah
29 Nov 2013 14:05
I am having the frame and swing arm on my '83 KZ1000R2 powder coated. Since I'm powder coating the swing arm I need to remove the needle bearings (I've already bought new ones along with sleeves). When removing the grease seal I find to my big surprise, no bearings??? It seems as there are only bushings there from the looks of it, no bearings. Kind of looks like a bronze bushing?. Dunno how to remove this, because I'm not sure what it is?
I've attached a photo of the pivot. Any advices on what this is and how to remove it. Can I just knock on one end and knock everything out on the opposite end? There is supposed to be a collar of some sort in there seperating the two sides, and this should be possible to remove?
Help!!!
.T
Help!!!
.T
Attachment bilde.JPG not found
.Tommyboy
- zukdave
Re: '83 KZ1000R2 Swing arm bearings not there?
29 Nov 2013 16:20
You can NOT drive them through the arm.
Long rod in one side and drive the other side out.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- Bozo
- Ride it like u stole it
30 Nov 2013 02:24
Looks like the bearings were replaced with bronze bushes, interesting?. if you use a rod to belt them out they might (depending on how tight they are) go out of shape. What are you thinking of doing - refitting original bearings??
- tommyboah
30 Nov 2013 04:03Bozo wrote: Looks like the bearings were replaced with bronze bushes, interesting?. if you use a rod to belt them out they might (depending on how tight they are) go out of shape. What are you thinking of doing - refitting original bearings??
Yes, I have new bearings and sleeves to refit after powder coating. Just need to figure out the best way of removing the bronze bushings. I will try to find a rod to put in from the opposite direction av try knocking them out.
.T
.Tommyboy
