Sintered brake pads
- DOHC
- Those Doe-Hawks really go!
Sintered brake pads
18 Nov 2013 10:57
Can anyone provide some input on running sintered brake pads on bikes made before around '79? I've seen warnings that sintered pads should not be used in bikes not originally equipped with them.
My impression is that the later bikes have an insulating disk to thermally isolate the pad from the piston. Did the bikes with this insulator come with sintered pads? Does this mean sintered pads should only be used with bikes that have the insulating disk in the piston?
For example: 1979 KZ1000-B3 front caliper piston
As opposed to my '78 KZ1000 Z1R without the insulator: 1978 Z1R front caliper piston
And why did the '78 Z1-R get its very own set of brake pads, 43050-5003, that the database says were never used on any other bike?
It really comes down to this. The front brakes on my Z1R have pretty much no bite at all, feel very wooden, and require a ton of lever force to stop with any real urgency. For reference, I believe I'm running EBC brand (FA33) pads in the front.
I've rebuilt every part of the front system, and I believe it is in top mechanical condition. Some feeling is certainly lost in the oddball cable, and some blame may be with the dinky 38mm pistons found in the Z1R (less hydraulic mechanical advantage).
But I figure a pad with more initial bite would be helpful. Recommendations?
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
- guitargeek
Re: Sintered brake pads
18 Nov 2013 11:58
After trying the EBC HH pads, I won't use anything else. They're the grippiest pads you can buy.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- DOHC
18 Nov 2013 12:13guitargeek wrote: After trying the EBC HH pads, I won't use anything else.
Looking at the EBC catalog, they list the FA36 (organic) and FA36V ("semi-sintered"), but do not list an HH pad for any KZ1000 made before 1981.
It looks like they don't make an FA36HH (searching the catalog turns up zero hits). Are you running these on stock KZ1000 calipers?
'78 Z1-R in blue
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
- sbc1320
18 Nov 2013 12:31dohc wrote: Can anyone provide some input on running sintered brake pads on bikes made before around '79? I've seen warnings that sintered pads should not be used in bikes not originally equipped with them.
I just rebuilt and painted one front caliper and one rear caliper for my bike. Mine has the insulated pistons, but I bought some kevlar-organic pads and put in these that I rebuilt. I also put the same pads in the rear(the one currently on the bike now) about a month ago. I am going to put all this on the bike when I rebuild the front forks with new NOS tubes in a month or so.
According to my manual it says - "WARNING" - "Do not try to use later sintered-metal pads in calipers with early non-insulated pistons. The heat produced could boil the brake fluid and cause brake failure".
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
- guitargeek
18 Nov 2013 14:26Well, there you go.sbc1320 wrote: According to my manual it says - "WARNING" - "Do not try to use later sintered-metal pads in calipers with early non-insulated pistons. The heat produced could boil the brake fluid and cause brake failure".
- zukdave
18 Nov 2013 16:17
I've got some sinter'd bronz pad's in the front stock
1980 650F1 calipar and have seen no issue with heat.
In fact they don't stop that good and squeal a little till they do build some heat
but once hot they'll lock the front tire with a single disk setup.
SOHC I'll be down at Doc's tomorrow night come and say hi.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- sbc1320
19 Nov 2013 04:33
Under normal driving conditions I don't think they would get hot. Under more extreme conditons or track time could be a different outcome.
- zukdave
19 Nov 2013 09:37sbc1320 wrote: normal driving.
Does not apply.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
