1980 KZ 550 LTD fork oil capacity
  • dfinnegan71
  • dfinnegan71's Avatar Topic Author
14 Nov 2013 12:12 - 14 Nov 2013 12:14
#613067
Hey there, does anyone know off the top of their head the capacity of fork oil in 1980 KZ 550 LTD forks? Here comes the curve ball...ready? These forks have been lowered 2 inches internally with spacers. Does that change the amount of oil needed for proper function? How would I know if I have too much or too little in there? Thanks for your help!
1981 GPZ 550 mild custom
Last edit: 14 Nov 2013 12:14 by dfinnegan71.
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
Re: 1980 KZ 550 LTD fork oil capacity
14 Nov 2013 15:05 - 14 Nov 2013 15:06
#613076
The method used by almost ALL flattrack racers (with RWU lowered forks) is to remove the spring and compress the forks all the way down. Fill forks to 6" from the top re-install springs and caps & done. This is a great place to start. More oil gives slightly firmer ride, less oil gives slightly softer ride. Good luck, Paul
Last edit: 14 Nov 2013 15:06 by slayer61. Reason: details
  • loudhvx
  • loudhvx's Avatar
14 Nov 2013 16:27 - 14 Nov 2013 16:31
#613079
Too much oil will blow out the seals.
This PDF has the details of how to measure it, and a rough estimate to start you off with.
home.comcast.net/~loudgpz/GPZweb/Mnls/Kz...9to85_ThirdParty.pdf
Page 45 of the book, (page 55 of the pdf), has the instructions.
Page 69 of the book, (page 79 of the pdf), has the chart. If I recall, you are using KZ550C forks? They are in the chart.
Bike on center stand, forks fully extended, (front wheel off the ground), springs out, the oil level is 14 inches from the top opening of the forks.
Remember to pump the forks and recheck the level a few times.
Lowering the forks shouldn't require a change in level sinc it is measured when fully extended. That way the oil will be at the normal level when the forks get bottomed out or topped out from bumps and potholes.
Last edit: 14 Nov 2013 16:31 by loudhvx.
  • dfinnegan71
14 Nov 2013 18:28
#613091
Great advice fellas. Thanks!
