Footrest problem
- jsnabbs
- 1981 kawiKZ440
Footrest problem
12 Nov 2013 01:20
I've just ordered some kawi 440 footrest and tried to test them out. The guy i got the bike from had some ugly aftermaket rest on there, now i cant seem to get them sitting right. righthand side seems to be sitting to far forward.
Am i doing something wrong here or has the conection point been moved forward to suit the aftermarkets?
TIME TO TRADE IN THE PEDALS FOR SOME POWER
- 0Z.Z1R Mk2
Re: Footrest problem
12 Nov 2013 02:41
Oh dear...it would be ok if you had a short right foot and a long left one.
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
The following user(s) said Thank You: jsnabbs
- Stazi
12 Nov 2013 04:52
Look like you got two lefties, or the right one has the rubber piece flipped upside down.... :silly:
82 KZ1000-K2 LTD
- jsnabbs
- 1981 kawiKZ440
12 Nov 2013 06:18
Thats what i was thinking, i think i have two left side footrest. It cant be that the rubber is on upside down because the right footrest sits too far forward.
I still think the conecting point has been modified
are the connecting points in line on the frame? or has the previous owner moved one
- jsnabbs
- 1981 kawiKZ440
12 Nov 2013 06:20
this photo is from a forum member and the conection point seems to be off set
- Stazi
12 Nov 2013 06:52 - 12 Nov 2013 06:54Attachment footpeg.JPG not found
Looks like you have to mount it on the the bolt behind where you did - the one with the nut on it it your picture
82 KZ1000-K2 LTD
Last edit: 12 Nov 2013 06:54 by Stazi.
12 Nov 2013 07:24 - 12 Nov 2013 07:31
No eBay APP ID and/or Cert ID defined in Kunena configurationFor reference --
Per kawasaki.com
Per kawasaki.com
Last edit: 12 Nov 2013 07:31 by Patton.
12 Nov 2013 07:25 - 12 Nov 2013 07:32Maybe, maybe not. The ball of the foot needs to be able to press down on the brake pedal.Stazi wrote: Looks like you have to mount it on the the bolt behind where you did - the one with the nut on it it your picture
Having said that, who knows what the po did to the bike? I hope his welding skills were up to snuff, because a hard tail is going to take a beating. :ohmy:
Last edit: 12 Nov 2013 07:32 by martin_csr.
- slayer61
- KZR FLAG RELAY CARRIER #62
12 Nov 2013 07:48
- jsnabbs
- 1981 kawiKZ440
12 Nov 2013 10:33
It looks like it should sit in the place where the nut is, but it forsure didnt come from there as there is no flush surface for it to pull up hard onto.
And not that i know yet as i havent droppend the motor out, but i thought where the nut is is coming from the other side and is a attachment point for motor
- Cynjut
12 Nov 2013 14:26
I think the left footrest is in the pivot chamber upside down. If you pull the pivot (fold-up) pin (90243A in the diagram), you should be able to flip the footrest over, which should bring you into line.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
- jsnabbs
- 1981 kawiKZ440
12 Nov 2013 14:27 - 12 Nov 2013 14:29
I think what may have happened is PO moved left hand side back as the side stand now sits in front of the footrest. and as for the right side he has some other brake pedal so there is not enough clearance.
What say you guys?
What say you guys?
Last edit: 12 Nov 2013 14:29 by jsnabbs.
