need help with neck tube bearings on 1980 KZ750E
- motomadlin32
- Nebr_Rex
- Thank you received: 300
Buy new and buy roller, it's a safety issue.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- Thank you received: 2829
www.allballsracing.com/22-1014.html
- motomadlin32
in which case could i use the race from the '81 frame? but seemed it would be very difficult to get it out without damaging it due to the lack of a lip on the inside.
- motomadlin32
- guitargeek
- Thank you received: 50
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- motomadlin32
- motomadlin32
- JR
- Thank you received: 448
motomadlin32 wrote: Ok thanks guys! So just curious did they change the bearing design from '80-'81 or did one of the previous owners of the '81 do the conversion at some point?
You made me curious since I also have a 1980 KZ750E1 so I checked Kawasaki.com Owner Info, Parts Diagrams etc and it looks like Kawasaki used the same bearing and same races on on pretty much all the 750s - twins included - from 76 to 84. .....Or to answer your question then it looks like Kawasaki did not change bearing design from 80 to 81.
The All Balls stuff is good quality. I've used it to replace my wheel bearings and am thinking about replacing the steering head bearings next season.
- motomadlin32
- zukdave
- Thank you received: 229
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
