1977 KZ1000 Sticky Front Break
- chconger
06 Nov 2013 09:35
Hi All
First an introduction. I am just back into Z's after 20 years on four wheels. I went and purchased this beast imaged below last weekend.
So I have all winter up here to get things tuned up.
First up is a sticky from caliper. It seems that it will not release the wheel after a couple of squeezes. Is there something easy to try before I start pulling the system apart?
Thanks
Chris
Thanks
Chris
1977 KZ 1000-A
- KZQ
- Administrator
Re: 1977 KZ1000 Sticky Front Break
06 Nov 2013 09:40
I'd start with pumping some clean brake fluid through the system. Your symptom is usually either a plugged return hole in the bottom to the master cylinder reservoir or gunk between the piston and the caliper.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- slayer61
- KZR FLAG RELAY CARRIER #62
06 Nov 2013 10:05
Brother, that bike is beautiful. Please don't be tempted to cut it all up.
- chconger
06 Nov 2013 10:11
Thanks ! -- My goal is to keep it stock as can be. The side covers are the only issue cosmetically right now. They became blue along the way,
I will try to run new fluid through and see if that cleans it out. Ill post back.
Cheers
Chris
Cheers
Chris
1977 KZ 1000-A
- sbc1320
06 Nov 2013 10:35
Sounds like time for a caliper rebuild. I just did a spare for the rear of mine even though my two front and single rear have all been rebuilt.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
- ed spangler
- Tennessee Z
07 Nov 2013 02:53
Welcome from East Tennessee!! :woohoo:
TennesseeZ Ed
TennesseeZ Ed
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
- chconger
31 Dec 2013 11:26
Dusting off my old thread here.
I have the caliper off and apart. Lots of crud in there, so may explain a lot. Going to put a rebuild kit in, as the caliper bolt dust covers are gone.
I already purchased a kit for the master cyl. Even though it appear ok, the break fluid was pretty gritty, so I want to start out now with everything fresh. I am now stumped how to remove the circlip that sits in front of the C Clip.
I am refering to the lower middle part in this image here;
I have the "round" master
Any advice there?
Thanks and Happy New Year
Any advice there?
1977 KZ 1000-A
- sbc1320
31 Dec 2013 11:34 - 31 Dec 2013 11:43
Last edit: 31 Dec 2013 11:43 by sbc1320.
- chconger
31 Dec 2013 11:45
Part number 19. I cant figure how to get it out of there?
1977 KZ 1000-A
- sbc1320
31 Dec 2013 11:47 - 31 Dec 2013 11:49chconger wrote: Part number 19. I cant figure how to get it out of there?
Without having it in front of me, it looks like a sharp pointed knife or an awl could be used to spring it inward(while keeping the plunger partly depressed) so you can slip a small blade screwdriver under it. Be careful not to lose it if you need it and Good luck. I have rebuilt my calipers, but not my master as it was already changed out by previous owner.
Last edit: 31 Dec 2013 11:49 by sbc1320.
- chconger
31 Dec 2013 11:55
Thanks...I have been poking / prying at it with an awl for a while today. Its starting to look like one of the things that require a nights sleep to resolve.
Cheers
Chris
Cheers
Chris
1977 KZ 1000-A
- sbc1320
31 Dec 2013 13:10
Sharpen an old small screwdriver(smallllll) and give it a try while keeping the plunger depressed slightly. Just make the screwdriver blade really flat and pick at it.
