Kz 750 ltd shaft - forks
  • Troyn
  • Troyn's Avatar Topic Author
03 Nov 2013 09:23 - 03 Nov 2013 09:34
#611942
Hello all. Looking for some forks and confused about model designations, part numbers etc. (not just for the forks!).
Does anyone know the difference between "k351" forks and "k309"??
Mine is an 83. Thanks!
1983 kz750 ltd shaft, 4-cyl, stock everything :)
Last edit: 03 Nov 2013 09:34 by Troyn. Reason: Was 307
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Kz 750 ltd shaft - forks
03 Nov 2013 16:25
#611976
Put your bike in your signature and go read the stickies in the new members section.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • martin_csr
  • martin_csr's Avatar
04 Nov 2013 06:02
#612011
It's doubtful that anyone is going to know what those fork numbers mean.
Kawasaki.com & Parzilla are a couple of handy places for comparing stuff. Click the part number for the cross-reference.
Your F1 Ltd-Shaft is most similar to the 750 Spectres which are also shaft drive bikes - they have a gold/black color scheme instead of silver/chrome. The forks on your bike are the leading axle type, typically found on many Ltd models - the axle is kinda forward of the fork legs. If you can't find forks specific to the F1, you might be able to use the forks from a 750H-Ltd (chain drive). From the diagrams they appear to be very similar, except they don't have the headlight ear fork covers nor do they have the cross-over air valve assy. But I really don't know if there will be any fitment problems. The upper tubes should be the same diameter, but strangely to me the cross-reference seems to indicate that they don't use the same fork seals.
The following user(s) said Thank You: Troyn
04 Nov 2013 06:55
#612015
Troyn wrote: Hello all. Looking for some forks and confused about model designations, part numbers etc. (not just for the forks!). Does anyone know the difference between "k351" forks and "k309"??
Hello, Troyn, and WELCOME to KZr! :cheer:
There's lots of good info on kawasaki.com, including parts diagrams, part names, part numbers, models sharing same part, availability, etc. Here's a link for help with navigating the site and finding information.
www.kzrider.com/forum/13-bike-related/37...imitstart=0&start=20
Good Fortune! :)
  • Troyn
04 Nov 2013 08:29
#612032
Thank you for the welcome and info! I'll take a look, appreciate it. :)
