KZ1100 fork caps
- gpzracer
- ´82 Gpz 1100
KZ1100 fork caps
24 Oct 2013 08:49
Anyone can tell me where can i buy fork caps for the kz1100 B2, been lokking everwhere i cannot find.
Thnaks
Thnaks
Ton up or go home.
Re: KZ1100 fork caps
24 Oct 2013 10:25 - 24 Oct 2013 11:13
Here's one. Spring seat - 360688902642
Ohio Cafe Racers fork tube conversion chart.
Several models have the same size upper fork tubes (38mm), so you might be able to use the fork plugs from one of those. Possible alternative: ebbaayy item # 121013773039
I don't know if it will fit - even if the threads are the same, the hex head may interfere w the handlebars or something.
Last edit: 24 Oct 2013 11:13 by martin_csr.
- gpzracer
- ´82 Gpz 1100
24 Oct 2013 10:39
i found this one but i dont know if it fits.
japan.webike.net/products/21344594:2390c...2d51761044ffb44.html
Ton up or go home.
24 Oct 2013 11:12 - 25 Oct 2013 09:14
I would contact them & ask.
As for the Spring Seat I linked above, I'm not sure that is the correct part. There appear to be fork plugs in the Handlebars diagram which are listed as BOLT,FLANGED,34X40,BL, but they look similar to the part you linked.
Last edit: 25 Oct 2013 09:14 by martin_csr.
