Anyone put low bars on a MKII?
  • 300kph
  • 300kph's Avatar Topic Author
14 Oct 2013 18:24 - 14 Oct 2013 18:25
#610001
OK< that's a dumb question...
ATTN: People who have put low bars on a MKII...
I would like to put a lower set on my 79 MKII but not sol low I have to swap out all the hoses and cables.
Something Z1R-ish would be my pick.
Anyone have experience with such a conversion?
I doubt Z1R bars would work but I am all ears.
Wayne
1978 KZ1000 D1 (Z1R)
1979 KZ1000 A3 (MKII)
1979 Honda CBX (Candy Glory Red)
1980 Suzuki GS1100E (Silver)
1980 Suzuki GS1100E (Red)
1978 Yamaha XS1100
1982 Suzuki GSX1100S (Katana)
1984 Kawasaki KZ1100R (Silver)
2004 Honda Rune (Bloodstone Red)
Last edit: 14 Oct 2013 18:25 by 300kph.
  • turboking
  • turboking's Avatar
Re: Anyone put low bars on a MKII?
14 Oct 2013 18:53 - 14 Oct 2013 18:57
#610002
my mk II has superbike bars and I used all oem hose and cables HTH :lol:
[IMG
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
Last edit: 14 Oct 2013 18:57 by turboking.
  • turboking
14 Oct 2013 18:54 - 14 Oct 2013 18:55
#610003
better pic... :lol:
[IMG
1985 GS 1150E
1983 GS 1100E
Last edit: 14 Oct 2013 18:55 by turboking.
  • Dr. Gamma
  • Dr. Gamma's Avatar
14 Oct 2013 20:06 - 14 Oct 2013 20:14
#610011
I would use the KZ1000D1(Z1R) clutch cable 54011-070. It makes for a lot cleaner routing of cable.
I got away with using the stock throttle cables by routing them under the headlight ear instead of up by the top triple tree like on the stock cable routing.
I always move the bars from side to side while I open and close the throttle to make sure they do not stick anywhere after installing or rerouting the cables.
I have used the stock Z1R bars, but I ended up with using some old K&N Superbike bars because I liked the bend of the bars better!!!
1986 RG500G 2 stroke terror.
Last edit: 14 Oct 2013 20:14 by Dr. Gamma.
  • RonKZ650
  • RonKZ650's Avatar
14 Oct 2013 23:21
#610034
I ran superbike bars the whole time I rode my MKII, nearly 80,000 miles in 8yrs, which isn't a huge amount I suppose, but it was a huge improvement. Used the Z1R clutch cable. Kept stock cables otherwise. The throttle cables were always obviously too long for the bars and adjustment to the push/pull was pretty much fruitless. The cables would always interfere with each other and throttle would stick. I eventually gave up the push cable, and just used the pull and it worked fine.
After I retired the MKII I put back on the stock bars just to be back original, but if I was planning to ride it again any distance I would not hesitate to put on lower bars.
  • 300kph
15 Oct 2013 01:24
#610040
I forgot about K&N superbike bars. What about Z1R bars? would they accommodate the cables an switches?
I think the Z1R bars are not quite as low as the K&N's.... Good idea using the shorter clutch cable. Wonder if the shorter throttle cables off the Z1R would also fit the MKII.
Anyone?
1978 Yamaha XS1100
  • Dr. Gamma
15 Oct 2013 01:46 - 15 Oct 2013 01:51
#610041
300kph wrote: I forgot about K&N superbike bars. What about Z1R bars? would they accommodate the cables an switches?
Anyone?
All the Z1r cables have been discontinued from Kawasaki according to their website. I put my extra Z1r cables on Ebay a few years back and I could not believe what I got for them. Now I know why!!!! All the KZ900/1000(1976 to 1980) throttle cables interchange. Sold many Z1r cables for people that put Superbike bars on their LTD's back in the day.
I don't think K&N even make handlebars anymore either.
Last edit: 15 Oct 2013 01:51 by Dr. Gamma.
  • racer54
  • racer54's Avatar
15 Oct 2013 03:36
#610044
There are many differnt versions of these bars out there. Dofferent rises and pullback measurements. MotionPro can or probably have whatever cables you would need. Maybe Z1 Ent. can help in this area....they are the go-to site for most things we need for these bikes.
