will 750 Rear Wheel fit 1000?
- Nelson
03 Jul 2006 22:41
Hi all:
I'm lookin at a 81 KZ750 Rear wheel. 18" mag with disk and sprocket. Looks like it should fit my 78 KZ1000A, but hard to say for sure. Anyone know??
thanks!
thanks!
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
- steell
Re: will 750 Rear Wheel fit 1000?
03 Jul 2006 22:58
If you rest your cursor on the "KZ Information tab at the top and look on the left you will see the "Filebase", click on it and look around page 4 for the Kawasaki wheel bearings list, that will tell you what wheel bearing fit your bike and what other models use the same ones.
I can tell you it's not a direct swap, they use different size bearings,which means the axles are different diameters.
78 KZ1000A and 76-80 KZ750 twins have the same axle size front and rear, KZ650 has the same front axle diameter.
- Nelson
03 Jul 2006 23:21
Great info, thanks!
Do you think bearings are the only difference? That's easy. Is rotor the same size? Hub the same width? etc?
Maybe I should just keep looking, but this one's pretty tempting.
thanks!
thanks!
- steell
04 Jul 2006 07:49
The KZ750 axle has a smaller diameter than the KZ1000.
I know that some people have just bolted it in, but I'm not a big fan of using a smaller axle in a larger hole, but you could get a couple of spacers made that would slide over the axle on each side. Be sure and get the cush hub and spacers if you do that.
I don't know about the rotor diameter.
