Help removing the lower stem bearing 1981 GPZ1100
  • old-school
  • old-school's Avatar Topic Author
29 Sep 2013 08:56 - 29 Sep 2013 10:20
#608185
The lower stem bearing on KZs I just normally used my bearing splitter and press but on the GPZ the stem has the fork stops stops to where you would have to have something that is 2 1/2" or narrower to get around the lower bearing or a puller that has more than a 9" reach and I do not have one of these either. Looking for some help.
Thanks
(2) 76 KZ900s, 81 CSR1000 and 81 GPZ1100
Last edit: 29 Sep 2013 10:20 by old-school. Reason: subject - added help
  • Motor Head
  • Motor Head's Avatar
Re: Help removing the lower stem bearing 1981 GPZ1100
29 Sep 2013 11:55
#608222
Cut eh cage, and ditch the rollers. They cut the race all with a Cut Off wheel on a Die Grinder. You can cut at an angle, once nearly through be careful not to hit the stem. May need to use a chisel to wedge in the cut groove to break the last bit of race metal. It will slide right off.
The following user(s) said Thank You: old-school
  • old-school
29 Sep 2013 14:51
#608233
I ended up cutting a v in the lower bearing race once the bearing cage was removed and chiseling the race off without hurting the stem. Thanks again for the help
