1982 KZ1000 LTD streetfighter build
  • Stazi
  • Stazi's Avatar Topic Author
Re: 1982 KZ1000 LTD cafe build
20 Dec 2013 17:16 - 20 Dec 2013 17:18
#616043
OK, enough of the silly buggers. LOL
I'm taking my thread back over.
Here's how she sits as of tonight.
82 KZ1000-K2 LTD
Last edit: 20 Dec 2013 17:18 by Stazi.
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: 1982 KZ1000 LTD streetfighter build
20 Dec 2013 19:13
#616052
really looking good......... B)
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
23 Dec 2013 06:29
#616201
ah pictures!!!!!!!
now thats a good boy :P !!!!!!!
looking good man!
keep us posted,
  • Stazi
23 Dec 2013 15:20 - 23 Dec 2013 15:23
#616252
More pics without the trick extensions Leon made me......might not need them after all. Got my 5/8" sprocket in and lowering links too.
82 KZ1000-K2 LTD
Last edit: 23 Dec 2013 15:23 by Stazi.
  • spdygon
  • spdygon's Avatar
23 Dec 2013 16:24
#616263
looking really good......
leon does a great job may have to contact him myself.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • Stazi
09 Apr 2016 05:49 - 09 Apr 2016 06:01
#720019
OK, site it has been years since I've given update on this project. I know a lot of people stop projects on here and then disappear into the wind, and I didnt want to be like that myself
The bike is essentially complete now. The only thing I'm waiting on are front brake lines I had to have custom-made. I ordered some from Galfer and they sent me two of the custom rear lines (only ordered one!) and not the front lines, so as of now I only have rear brakes.
I tried shaving down the seats by myself to give it a bit more of a sleek look but it still has that ghastly LTD shape to it. There is a company that makes the café seat for it, but they charge $210 for the seat and a ridiculous $90 for shipping. I know I should just pay for it, but I can't bring myself to pay for that kind of shipping. Maybe eventually I'll suck it up and do it but it pisses me off.
I was very apprehensive when I went to start this bike, again for the first time in years, because I had put in stage III Dynojet kit, after completely disassembling the carbs. I also completely disassembled the head, and removed as much carbon as I could from the combustion chamber and also very reground the valve seats, ever so slightly. I did a mold porting/polishing of both the intake and exhaust ports, and I installed a set of Web street cams that I found on eBay that someone had bought for the project but realize they didn't work on a turbo set up.
But my fears were set aside when it fired instantly the first time I tried to start it. I just had to balance the carbs again with my Mercury Morion Pro manometer and even the suggested mixture setting by Dynojet was spot on after I checked each of the cylinders with my Gunson colortune kit.
I even got the knockoff Koso instrument cluster to work, although the tachometer portion of it is not working properly (not accurate). everything else including the speed and even the fuel tank levelis fine. I think I just got a bad one, so I might roll the dice on buying another one that I have my eye on.
Pics aren't uploading (too big) so you can see them here on my tumblr
staziskz1000build.tumblr.com/
82 KZ1000-K2 LTD
Last edit: 09 Apr 2016 06:01 by Stazi.
  • Rockranch
  • Rockranch's Avatar
09 Apr 2016 06:25
#720024
Nice work. Tho' I am curious as to how did your Henry Abe airbox work out that you mentioned in your Tumblr postings? ......................Mike
Vroom-vroom!
(2)-1976 KZ900B-LTD's
1-all stock low mileage...
1 modified
1977 KZ1000 (awaiting resurrection!) :)
...and an old school Honda CB750 Chopper is next on my bucket list!
Oh...and a Pocket Rocket lol!!!
  • Stazi
09 Apr 2016 06:47
#720031
Ha! I still have it, but the carb boots are the wrong size; they're too small in ID to slip over the BS34 intakes which are 55mm I'm trying to work out whether I could use Gixxer 1000 air box boots for it. As they look like they might. I asked a seller on eBay with those boots to measure them for me, but still waiting on a reply. For now it runs perfect on the stock air box with a K&N in it.
It would look awesome with the Henry Abe air cleaner on it though, if I can find boots that will fit both the carbs and the box. The KZ1000 boots are too long and have funky dog legs to them.
82 KZ1000-K2 LTD
The following user(s) said Thank You: Rockranch
  • Rockranch
09 Apr 2016 07:42
#720034
I was recently searching for (and found) an Abe breadbox for my upcoming build, ( I LOVE the look) however I opted to pass on it for now as I figured the same fitment issue with my RS38 Mikunis. However with a bit of machining and ingenuity, it wouldn't be all that hard to fabricate them to match up successfully with my carbs. I still may very well go with that idea at a later date. I had one years ago on another 900 and lined the inside of the boxes end openings with a thin rubber so to eliminate the effects that crosswinds can cause with open air intakes such as breadboxes and pods. Still had more than enough air flow to the carbs and it ran great for years without any low rpm hesitation/bog issues. Much of the tuning difficulties with pods and such, is too much unrestricted free air flow to the carbs. The air flow of these types of air boxes can easily be customized and varied at one's preference and tuning needs (especially the 'crosswind effect') using the rubber strip lining method, and will not alter their appearance at all. ..........................................Mike
Vroom-vroom!!!
1 modified
  • tallmangram
  • tallmangram's Avatar
03 May 2016 14:22
#724325
Hey could you tell me where this $300 seat maker is? I am not going to open that can of worms and make a custom one. Thanks
  • Irish-Kawi
  • Irish-Kawi's Avatar
03 May 2016 15:04
#724340
Welcome back Stazi and good to see that you stuck with it and didn't let this build float on into obscurity!! Nice work and like the results, thanks for sharing!
Brett
All the gear all the time!
1985 Kawasaki GPz 750 (ZX750-A3) 15,000 original miles www.kzrider.com/forum/11-projects/601230...z750-refresh-project
Father - Husband - Bourbonr - Rider
The following user(s) said Thank You: Stazi
  • Stazi
03 May 2016 23:10 - 03 May 2016 23:11
#724447
tallmangram wrote: Hey could you tell me where this $300 seat maker is? I am not going to open that can of worms and make a custom one. Thanks
These are the guys. They make the seats in Vietnam and ship them here, so a large portion of the cost is the shipping. I'm looking forward to receiving mine soon
www.motorcycleseatsdirect.com/1981-1982-...afe-motorcycle-seat/
82 KZ1000-K2 LTD
Last edit: 03 May 2016 23:11 by Stazi.
