18" rear wheel on 82 kz 750 ltd?
  • Jrbrownie00
  • Jrbrownie00's Avatar Topic Author
24 Sep 2013 22:18
#607655
Can it be done fairly easily? Looks like the gpz used an 18"
82' kz750 ltd.
  • martin_csr
  • martin_csr's Avatar
Re: 18" rear wheel on 82 kz 750 ltd?
25 Sep 2013 10:17
#607713
I don't know, but until you get a definitive answer, what you can do is compare the Rr hub & brake parts to the GPz or 750E at Kawasaki.com. If everything seems the same, then it may work. (???) You may need to figure out if different spacers are needed so that the sprocket & Rr Br disk line up. I don't know if there will be clearance issues w the 18" wheel - ie, whether or not it will rub the fender or something.
  • Beaner242
  • Beaner242's Avatar
25 Sep 2013 16:48 - 26 Sep 2013 08:36
#607745
and i have a mag off a 82 it you need measurements
1982 KZ1000K LTD Chopper
Last edit: 26 Sep 2013 08:36 by Patton. Reason: delete solicitation
  • Jrbrownie00
25 Sep 2013 17:21 - 26 Sep 2013 08:39
#607754
Beaner242 wrote: and i have a mag off a 82 it you need measurements
an 18" or 16"? I have the 16.
82' kz750 ltd.
Last edit: 26 Sep 2013 08:39 by Patton. Reason: delete solicitation
26 Sep 2013 08:41 - 26 Sep 2013 08:42
#607840
PRODUCT OR SERVICE ADVERTISING IS STRICTLY LIMITED
KZrider.com is not a place for you to solicit sales of any kind...
permitted in Classifieds (consumer-to-consumer transactions)....
Good Fortune! :)
Last edit: 26 Sep 2013 08:42 by Patton.
  • Beaner242
26 Sep 2013 10:10
#607845
i have an 18 inch wheel yes.
