What to do About a Torn Dust Boot
  • PaulyWally
  • PaulyWally's Avatar Topic Author
  • Total Bike Newbie
23 Sep 2013 19:23
#607473
I've got a torn dust boot - the rear master cylinder.
I can't find them available anywhere. Kawasaki.com says it's discontinued. I've checked a few aftermarket sites with no luck yet. The same part number was used on '76-'79 KZ750... but that was it. Which is probably why it's a tough find. I haven't dug up anything on eBay either.
So... if I am unable to find one. What are my options?
Thanks!
1976 KZ750 Twin
  • zukdave
  • zukdave's Avatar
Re: What to do About a Torn Dust Boot
23 Sep 2013 20:13 - 23 Sep 2013 20:20
#607480
Call Rob at Z1 enterprise if anyone can find it it'll be them.
I looked real quick and this might work for you.
www.z1enterprises.com/ItemDetails.aspx?i...f1100&item=KL32-1286
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Last edit: 23 Sep 2013 20:20 by zukdave.
  • MDawnz1
  • MDawnz1's Avatar
24 Sep 2013 21:34
#607649
If all else fails,
Check an auto parts store the carries "HELP" products.
They make all kinds of stuff like that.
I don't know if they are online, but it's a DORMAN co.
Mike
1974 Z1a, still 903
24 Sep 2013 21:58 - 25 Sep 2013 10:40
#607651
www.gearhead.com/catalogsearch/result/?q=43024-002
Appears to allow adding 43024-002 to the cart, as if one is available.
Might want to give'em a call.
Good Fortune! :)
Last edit: 25 Sep 2013 10:40 by Patton.
  • martin_csr
  • martin_csr's Avatar
25 Sep 2013 10:35 - 26 Sep 2013 11:38
#607717
Partzilla lists 43024-002 as PRODUCT OBSOLETE. I searched the part number on ebbaayy w no luck.
If there's a Kawasaki dealer nearby, try asking them to do a search. Kaw dealers supposedly have a nationwide product search that may turn up something if a dealer somewhere happens to have an otherwise Cancelled part listed in their system.
Some other models have the same brake rod, piston assy, & primary cup, so perhaps you could use the boot from one of those? For example, the 1978 KZ1000-C1 Police - the dust boot should still be available - #43024-003 is listed as Active at Kawasaki.com.
Last edit: 26 Sep 2013 11:38 by martin_csr.
  • pete greek1
  • pete greek1's Avatar
25 Sep 2013 12:47
#607727
www.matthewsfunmachines.com/index.htm .... d136nqpz68vrmx.cloudfront.net/website/im...include-1044x150.png ... or call redline cycle, ask for Jim, 847-675- 2020 .....Good Luck, Pete
  • weales
  • weales's Avatar
09 Oct 2013 01:10
#609323
Try www.Midwestactioncycles.com - they've got a pretty good range of Z stuff!
Current Project
1968 Norton P11A Desert Sled
Other bike (and daily ride)
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
