GPz750 (Zx750A) 530 chain conversion?
  • StreetfighterKz
  • StreetfighterKz's Avatar Topic Author
19 Sep 2013 12:44
#607050
I'm picking up a '83 Gpz750 Saturday to add to my ever growing motorcycle collection.
Anyways, I know it needs a rear sprocket and chain but it uses a 630 chain. I searched JT and Sunstar sprockets and neither one offered a 530 conversion for the bike. As a matter of fact, one of them didn't even offer a front sprocket whatsoever.
PBI sells a 1/4" offset front that should be close to the stock offset but in 530. Anyone ever used that? If so, do you have a part number for a 530 rear sprocket?
Thanks.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • Cynjut
  • Cynjut's Avatar
Re: GPz750 (Zx750A) 530 chain conversion?
19 Sep 2013 12:51
#607053
I did a 530 chain conversion on me 82 KZ1000. Bought all the parts from Z1 Enterprises. Jeff had to do some research, but he got me squared away in no time.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
  • steell
  • steell's Avatar
21 Sep 2013 01:10 - 21 Sep 2013 01:12
#607220
Cynjut wrote: I did a 530 chain conversion on me 82 KZ1000. Bought all the parts from Z1 Enterprises. Jeff had to do some research, but he got me squared away in no time.
The KZ1000 does not have an offset front sprocket stock, so it doesn't apply.
10mm offset sprocket sounds about right, and I think 17/45 in 530 sounds about right.
I used a 83 GPz750 motor in a 650 frame and used PBI offset sprocket.
And I think the rear sprocket has to be a custom, I used Sprocket Specialist.
Last edit: 21 Sep 2013 01:12 by steell.
  • zukdave
  • zukdave's Avatar
23 Sep 2013 20:35 - 23 Sep 2013 20:35
#607485
ZX750A1 is a 1984 model that's what my motor came out of.
I run the standard KZ650F1 530 sprocket on mine it's a bolt on.
I still have the 630 rear off the GPz I'll check tomorrow if it's
the same bolt pattern.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Last edit: 23 Sep 2013 20:35 by zukdave.
  • StreetfighterKz
24 Sep 2013 08:20
#607554
zukdave wrote: ZX750A1 is a 1984 model that's what my motor came out of.
According to Kawasaki.com's parts diagram the Zx750A1 is an 1983.
Anyways, I did some more digging, and it appears the Gpz750 Turbo uses the same rear sprocket, just more teeth, but a couple companies make a 530 conversion for it. So a PBI front sprocket and a 530 conversion for a Turbo model should set me up...I think.
Later, Doug
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
  • zukdave
  • zukdave's Avatar
24 Sep 2013 08:59
#607556
Doug your right hell it's right there in my sig.
Damn beer get's in the way of thinkin some time's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • StreetfighterKz
24 Sep 2013 09:07
#607559
zukdave wrote: Doug your right hell it's right there in my sig.
LOL! It's all good. B)
Later, Doug
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
  • Ltd-18ner
  • Ltd-18ner's Avatar
14 Sep 2017 13:06
#770907
I know this is an older thread. But I'm dealing with this exact thing.
Doug - was that offset front sprocket the way to go?
