kz750 ltd to kz1000 ltd mag wheel swap question
  • KZ802
  • KZ802's Avatar Topic Author
19 Sep 2013 00:03
#607005
I have a 1980 KZ750 LTD that I already put in storage. The mag wheels are in need of redoing. I also have a 1978 KZ1000 LTD that I'm putting modern wheels on. I have the mag wheels off of that bike already. Anybody know if they are the same size and I could just swap them? I haven't had a chance to go to my storage unit to see if they are the same size yet. I'm hoping I can refurbish the wheels and just swap them over when I'm done.
1980 KZ750 LTDx2
1978 KZ1000 LTD
1976 KZ900 A
  • steell
  • steell's Avatar
Re: kz750 ltd to kz1000 ltd mag wheel swap question
21 Sep 2013 01:16
#607222
I'm pretty sure the axles are different sizes, you can check the parts diagrams at kawasaki.com to confirm.
  • martin_csr
  • martin_csr's Avatar
21 Sep 2013 12:16 - 02 Oct 2013 08:48
#607252
In regards to the axle sizes, could he use different wheel bearings?
I'm pretty sure my neighbor put a KZ1000 front wheel on his 650-CSR which has the same axle as the 750-4s, but I don't know from what 1000 he got the wheel. I think he had to use some spacers or something to line up the brake disk. The CSR is a single disk - I don't know if a dual disk would be problematic for your bike. Also, I kinda recall that the speedo drive didn't quite fit right - it doesn't contact the fork stop properly or something like that, but it works.
Are the 78 1000 wheels tube-type or tubeless?
Last edit: 02 Oct 2013 08:48 by martin_csr.
  • KZ802
01 Oct 2013 22:55
#608516
Both sets of wheels are tubeless. They both look the same, and they are both 19 up front and 16 in the back. I will check the parts diagrams. I was hoping I would get lucky and it would make my job way easier but whatever. I guess I'll just take off the wheels and fix them if I have to.
1980 KZ750 LTDx2
1978 KZ1000 LTD
1976 KZ900 A
01 Oct 2013 23:08
#608517
Are your KZ1000 wheels stock? Stock 1978 KZ1000-B2 (LTD) wheels are tube type; not tubeless (see diagrams 1 & 2 below). The 1980 KZ750-H1 (LTD) wheels are tubeless. It is fine to run tubeless tires on tube type wheels, but you MUST use tubes in them. Ed
Attachment 00001_2013-10-01.jpg not found
Attachment 00002_2013-10-01.jpg not found
Attachment 00003_2013-10-01.jpg not found
01 Oct 2013 23:15 - 01 Oct 2013 23:17
#608519
Tubeless wheels have an extra rim to keep the tire in place if you lose air; tube type do not have that extra rim. Ed
Attachment wheelstubeless.JPG not found
(Pics courtesy Patton)
Last edit: 01 Oct 2013 23:17 by 650ed.
  • martin_csr
02 Oct 2013 08:45
#608539
Here's a KZ550 Rr wheel that has "Tubeless" cast into it. The ridge isn't as prominent as the one in the above photo.
