Modern Fork Swap
- treitz
Modern Fork Swap
18 Sep 2013 16:58
I found a deal on a set of 2006 GSX-R forks that is just too good to pass up. If I can't get them mounted on my bike I'll just sell them online and make a few bucks.
Wondering if anyone on here has put a modern front end on a KZ400 or similar bike? And if so, what all was involved.
Forks come with a upper triple, but no lower. So I would have to have that manufactured. (Note: My grandpa is a machinist)
Points of concern/question...
1) Making my wheel fit
2) Mounting my brake caliper
3) Triple tree
3) Triple tree
1979 KZ400 - 2-1 Manifold - Mikuni VM34
Re: Modern Fork Swap
19 Sep 2013 12:45
buy a stock gsxr lower triple and swap your kz stem into the gsxr lower,bush or bore your upper to match the kz stem and voila' it bolts on using the kz bearings and hardware.
custom spacers will get the wheel in there,custom bracket will make the brake fit.
hth,
hth,
- barreto
08 Oct 2013 16:04
Swing by my shop in Boise sometime. I have an XR600 and a Virago with modern forks. If you want, I could do a swap on yours.
- jmoney05
16 Oct 2013 02:19 - 16 Oct 2013 10:34
I just picked up a 2006 gsxr 1000 complete front end, also came with an extra lower triple that I believe is off of a gsxr 600!
If your front end is of a 600, check KZr classified for sale.
I plan on doing a swap on my bike as well.
1978 Kz650D
Last edit: 16 Oct 2013 10:34 by Patton. Reason: delete solicitation
- stpierre
16 Oct 2013 23:36
Let me know how you make out with your 2006 gsxr 1000 complete front end swap.
Pics are nice as well.
Thank you.
Thank you.
- RedBullEnema
- Longtime Lurker/Knowledge Collecter
22 Oct 2013 13:46
I would recommend a visit to the shop section of this guys site:
Cognito Moto
He happens to be currently providing parts to easily graft most years GSXR front ends on our older bikes. Im about to send him my lower triple to have him press in his new stem (measurements show it will work on my '78 650).
He's a super cool guy, drop him a line if you have any questions.
Cognito Moto
1978 KZ650-B2
Iteration 1 - Cafe seat, polished and oiled tank, plate/brake light combo.
Iteration 2 - Upgraded wiring, LED tail light, HID headlight.
Iteration 3 In Progress - Z1 seat, '09 GSX-R600 front end, ZRX1200 swingarm, and much much more!
- stpierre
22 Oct 2013 17:41
Cool thanks for the link.
Let us know how you make out.
- BohicaBob
23 Oct 2013 00:10 - 23 Oct 2013 00:12
You might be able to purchase the required bearings from
ALL BALLS RACING
in order to make the swap of front forks without the need for stem swaps. I installed a '99 ZRX1100 front fork triple tree on my '78 KZ1000/A2 just by purchasing the correct bearings and adding three homemade shims between the '78 KZ1000 top triple tree's original steering stem cone and the '99 ZRX1100 top triple tree's 25mm nut:
Last edit: 23 Oct 2013 00:12 by BohicaBob.
The following user(s) said Thank You: BlackZ1R
- treitz
23 Oct 2013 11:27
Sorry I've been MIA. I ended up not picking up the forks because I thought I would be getting in way over my head. I'll probably do a modern swap on my next build.
Thanks for all the input regardless.
- jmoney05
26 Oct 2013 00:38
Mock up on parts bike first before I take apart my from end
1978 Kz650D
- BlackZ1R
- Kawasaki in my blood
26 Oct 2013 18:38BohicaBob wrote: You might be able to purchase the required bearings from ALL BALLS RACING in order to make the swap of front forks without the need for stem swaps. I installed a '99 ZRX1100 front fork triple tree on my '78 KZ1000/A2 just by purchasing the correct bearings and adding three homemade shims between the '78 KZ1000 top triple tree's original steering stem cone and the '99 ZRX1100 top triple tree's 25mm nut:
Bob, do you have any idea what bearings you bought, and were they in a kit from All Balls? I don't see where we can send Private Messages now. I'd like to see how this worked out for you. Do you have a build thread or any more pics of your swap?
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- moonbeam
27 Oct 2013 08:14 - 27 Oct 2013 08:16
Hi Bob,
I have a zx9R forks with the triple trees for my KZ1000 1977.I am buying the All Balls Racing Bearing as recommended,part nos :99-3509-5 and 99-3513-5.Is there any other mods to be done besides adding shims like you did on your KZ1000?
Thank you and regards,
Moonbeam
Moonbeam
Last edit: 27 Oct 2013 08:16 by moonbeam.
