A theoretical question on bracing
  • kzz1king
  • kzz1king's Avatar Topic Author
15 Sep 2013 23:59
#606626
If two pieces of tubeing were stacked on each other and welded together would they be stronger or weaker compared to the same tubes spaced apart a few inches with short pieces of gussets between the tubes every foot or so? The load in question would be straight down.
_______________________________
________________________________
or
___________________________________
II II II II II II
____________________________________
Not a great representation :huh:
Wayne
Home built KZ1000 turbo setup
  • Motor Head
  • Motor Head's Avatar
Re: A theoretical question on bracing
16 Sep 2013 00:01
#606628
I believe the second. I used something like that to brace my swinger, but in a truss shape/ angle.
  • kzz1king
16 Sep 2013 00:10
#606632
I am astonished I wrote clear enough for someone to understand my question, but yes that is what I am talking about. I want to make a light trailer frame and plan to use 2 tubes or pipes withgussets between every foot or so or welded together. Whichever is deemed stonger. Thanks for the reply.
Wayne
Motor Head wrote: I believe the second. I used something like that to brace my swinger, but in a truss shape/ angle.
  • testarossa
  • testarossa's Avatar
16 Sep 2013 07:59
#606645
I agree, # 2 is way stronger. Make the short cross braces at 45 degree angles so that they form triangles, and it will be even better.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • T_Dub
  • T_Dub's Avatar
16 Sep 2013 08:33
#606649
Yup, the further apart your tubes are, the stronger they will be in bending. Which is where most of the stress in any structure like that comes from. Make triangles as testa says and you'll be good to go.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • MDawnz1
  • MDawnz1's Avatar
16 Sep 2013 19:35
#606709
To answer your question , IF we only have 2 choices , then #2
# 3 would be 1 "I" beam and do away with a bunch of welding.
Mike
1974 Z1a, still 903
  • kzz1king
17 Sep 2013 20:27
#606844
Thanks guys. I have a bunch of pipe. I plan to build a light ice fishing shanty with pull up wheels.
Wayne
  • MDawnz1
  • MDawnz1's Avatar
18 Sep 2013 02:19
#606885
Silly me :laugh:
I thought it was for a bike trailer.
1974 Z1a, still 903
  • kzz1king
18 Sep 2013 17:25
#606953
MDawnz1 wrote: Silly me :laugh:
Actually I am going to make the door wide enough to accommodate one bike. The trailer will lay down so it will be easy to use.
Wayne
