How to adjust steering bearings?
  • car5car
  • car5car's Avatar Topic Author
  • Banned
  • Banned
06 Sep 2013 14:45
#605214
I am going just to eliminate up/down freeplay (everything is removed, only steering axle is in)
Is that right?
96 Yamaha Royal Star
82 Yamaha Virago 920
  • bountyhunter
  • bountyhunter's Avatar
Re: How to adjust steering bearings?
06 Sep 2013 15:55 - 06 Sep 2013 15:56
#605235
No, there is a very specific procedure on mine. You tighten the stem nut until play is just out then a little more (there is a torque spec). I adjust mine more by feel. With wheel up, you tighten until it starts to "bind" movement then back off until it turns freely.
Last edit: 06 Sep 2013 15:56 by bountyhunter.
  • car5car
  • Banned
  • Banned
06 Sep 2013 16:53
#605244
thanks!
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
06 Sep 2013 17:38 - 06 Sep 2013 17:38
#605247
You need to loosed the upper clamp fork pinch bolts so the clamp can be pushed down to lock the adjuster ring. Might need to give a light tap with a rubber mallet to free up any binding.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Last edit: 06 Sep 2013 17:38 by Kidkawie.
