530 Chain conversion COMPLETE!
  • BubbaZ1982
  • BubbaZ1982's Avatar Topic Author
03 Sep 2013 23:19
#604729
I Got my new chain and sprockets today for my '81 LTD 750. WOW, What a difference from the old chain. When I got the old 630 chain and sprockets off, I could really see how bad they were worn. But a few hours, some elbow grease and more than a couple Mosquito bites, and I now have a brand new chain and sprockets installed! Thank's Z1 Enterprises for making it so simple and for the fast shipping! I will post pics tomorrow.
  • Beaner242
  • Beaner242's Avatar
Re: 530 Chain conversion COMPLETE!
04 Sep 2013 09:27
#604759
on my list of to do's. do I get the same size sprockets that I have now?
1982 KZ1000K LTD Chopper
04 Sep 2013 09:44
#604765
Beaner242 wrote: on my list of to do's. do I get the same size sprockets that I have now?
Same diameters, but more teeth on a 530 sprocket.
Z1E provides conversion info, such as comparative sizes of 530 sprockets that match the stock 630 sprockets.
Good Fortune! :)
  • koolaid_kid
  • koolaid_kid's Avatar
04 Sep 2013 13:58
#604790
This is also a good time to update the ratio if you wish. The ratio is calculated by dividing the number of teeth on the front sprocket into the number of teeth on the rear sprocket.
For example, if you have 14 teeth on the front sprocket and 40 teeth on the rear sprocket, your ratio would be 40/14 = 2.86.
The larger the number the better the acceleration, but at highway speeds the engine revs would be higher. The lower the number, the lower the engine revs at highway speeds, and (usually) slightly better fuel economy. But at the expense of acceleration.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • BubbaZ1982
04 Sep 2013 15:26
#604807
I went with a 16/40 set for a 2.5 ratio. So far i'm loving it.
  • BubbaZ1982
06 Sep 2013 21:30
#605277
Heres a picture of my bike post conversion, Now I gotta cut down my chainguard brackets ( which I made).....
  • koolaid_kid
06 Sep 2013 22:05
#605290
Nice bike. What did you set your sag at for your chain?
1983 GPz 750
  • BubbaZ1982
06 Sep 2013 23:55
#605306
bout 3/4" in both directions
  • onebadram
  • onebadram's Avatar
07 Sep 2013 10:19
#605356
I just did this to my bike about 2 weeks ago. I went with a 16/38 combo. I just called up Z1 enterprises and they told me every thing I needed to order. Just call them up they are super help full.
81 kz 750 h2 ltd
  • BubbaZ1982
15 Sep 2013 22:40
#606617
UPDATE:
New chain and sprockets still working great after 2 weeks!
But I was stranded on the road today when the countershaft nut mysteriously disappeared. LUCKILY for me and my wife, a REALLY nice guy stopped and gave us a ride to an ACE hardware that VERY luckily, had a 20X1mm nut. I got all the spacers from Z1 enterprises when I did the conversion, but somehow it came loose. NOW I have a wave washer locking the nut to the shaft and sprocket. HOORAY for nice people in the world!!
  • Hawaii_Z1R
  • Hawaii_Z1R's Avatar
15 Sep 2013 23:11
#606620
Glad it worked out! Here was the response for my project:
To convert maintaining the stock gear ratio.
Use a 530 series 18t front, 40t rear and 110 links of 530 chain. (Linked below.)
www.z1enterprises.com/ShopByCategory.asp...ory=0101010401161101
Be sure to grab a couple of the SS-3 spacers just in case you need to shim out the front sprocket. Also a clip-style master link for the chain if you don’t want to use the included rivet-style link.
1978 Z1R
1976 KZ900
2017 Versys 300X
2021 CT125
  • BubbaZ1982
16 Sep 2013 20:30
#606714
be careful on that front sprocket size, I went with a 16 and it was a pretty tight fit in the housing.
