Installing new outboard brake pad
- savedrider
- 1975 Z1-B 900
31 Aug 2013 00:17
How freely should it slip through the caliper holder? I can barely get it to fit in the caliper holder bore. Seems to me it should move fairly freely. Do you usually need to sand the edges of the pad a bit to make this work? Thanks.
Get right or get left! <*{{{><
- MDawnz1
- savedrider
- 1975 Z1-B 900
Re: Installing new outboard brake pad
31 Aug 2013 15:47
Wow, what the heck am I doing wrong then? I've got a couple different brand new inboard pads and both are tight fits. The old pads I removed fit smoother. To the naked the eye they look the same diameter. I will put a mic on them and see.
- MDawnz1
31 Aug 2013 17:09
Your talking about the fixed pad with the bolt in the back right ?
And it wont drop into that little pocket ?
You have it all apart and clean with the piston compressed all ready to go back together ?
Try putting it on the edge of a solid workbench or a scrap of 2/4 ,
with the pad face down, line up the bolt hole so you can get it in next ,
and "tap" on the back of the caliper half over it,
Try the bottom of a hammer handle ,,,,DON'T hit it with the hammer head.
If that doesn't work, then im stumped without seeing it.
Mike
Mike
1974 Z1a, still 903
- savedrider
- 1975 Z1-B 900
31 Aug 2013 17:34
Actually it's the other pad, the one that touches the piston. Everything is clean as a whistle. Full disassembly and rebuild of caliper, new seals, etc. I actually have 3 different brands of new pads, each one fits a little different. I'm just going to keep sanding till they slide through the caliper bore smooth.
