Rear tire size
- Beaner242
Rear tire size
28 Aug 2013 11:25
I have a hardtail kit coming soon. I am running the factory rims at the moment. Black mags, front 19" and rear 16". Factory tire size is 130/90-16. The guy that I got the frame from says should be able to fit a 160 and possibly a 180 rear tire. Question is will this size tire fit on the factory rear rim? If not, does anyone know a place that will build custom rims? I would like to go with spokes anyway.
1982 KZ1000K LTD Chopper
- slayer61
- KZR FLAG RELAY CARRIER #62
Re: Rear tire size
28 Aug 2013 11:43
I cant help you with a spoked wheel, but if you're looking for a wider rear mag wheel, Sandy Kosman still offers a wheel widening service. Have a look at
kosmanspecialties.com/services/wheel-widening-and-weldups/
Good luck with your project.
- Beaner242
Re: Rear tire size
28 Aug 2013 12:28
thanks slayer. ill be contacting them for sure. i guess they can do spoke or mag wheels?
- david1050
Re: Rear tire size
28 Aug 2013 13:34
David
2009 Vulcan 900 Custom
1975 Z1B 900 Mod/Resto project (91 KZ1000P forks and wheels)
1976 KZ900 Cafe bought to flip
1982 KZ750R1/GPZ750 project (95 ZX7 forks, 03 ZX636 swingarm)
The following user(s) said Thank You: Beaner242
- slayer61
Re: Rear tire size
28 Aug 2013 13:57David1050 is right...
If you decide to go spokes, Buchanan's is the way to go. You provide a hub and they can supply the rest in any size, style or color you want... spokes, rim, assembly- everything.
If you decide to use mags, Kosman is the go-to guy. They have the ability to widen and change the diameter, if that's what you want. Sandy's crew created a 17X6 for me out of an LTD wheel for me years ago. Good luck again. Paul
- Beaner242
Re: Rear tire size
28 Aug 2013 14:03 - 28 Aug 2013 14:15
Great I knew I could count on you guys! Now just to find the right hub. off to the wanted section and flee bay i guess.
Last edit: 28 Aug 2013 14:15 by Beaner242.
- MDawnz1
Re: Rear tire size
29 Aug 2013 03:44
2 things ,
How wide can you go before the chain rubs the tire ?
And
Kosman is going through some stuff, they have changed hands like 3 times in the last 2 years.
Take my word for it, they are NOT the Kosman from years ago.
And
1974 Z1a, still 903
- Beaner242
Re: Rear tire size
29 Aug 2013 09:37
Well after some measuring last night, it seems ill just go with the widest tire i can on a stock wheel. Anyone know what that is?
- slayer61
Re: Rear tire size
That's good to know... my dealings with Kosman come from 20 years ago when Sandy still controlled the place.
- bluezbike
Re: Rear tire size
29 Aug 2013 13:39Beaner242 wrote: Well after some measuring last night, it seems ill just go with the widest tire i can on a stock wheel. Anyone know what that is?
Its not just the frame which is a consideration....I assume you have the stock swingarm? If so check how much clearance that gives you.
79 KZ 1000 LTD
- Kraz1
- Beaner242
Re: Rear tire size
29 Aug 2013 14:26
thanks. The stock swing arm is what i measured. the guy that is building the hardtail says i will have 9.25 inches between the frame rails. that is not much diff than stock. I guess I will wait until the frame is done before worrying about the wheel and tire. Dont want to buy things twice.
