bent/twiste steering stem/clamps help!
  • kamakazie1000
  • kamakazie1000's Avatar Topic Author
25 Aug 2013 08:40
#602963
Good morning Kzrider community!
I suspect my steering stem/triple clamps are bent it twisted. It's a 78 kz1000 with a 77kz1000 front end. The old fork tubes we're slightly bent so they have been rebuilt with new tubes, seals, and hardware. When I tried to slip the forks into the triple clamps I noticed that the forks don't align with the top clamp. Is there a way I can tell if my steering stem or clamps ate bent or twisted. I will upload some pictures when I get home later. I'm hoping this is as simple as just getting a new lower clamp/triple tree. Any suggestions, comments, concerns are welcome.
Regards.
Terminal lance corporal of Marines, putting the GRUNT in disgruntled
kz1000 cafe project
  • martin_csr
  • martin_csr's Avatar
Re: bent/twiste steering stem/clamps help!
25 Aug 2013 10:02 - 25 Aug 2013 10:02
#602976
Try placing the upper triple on a glass table & pressing down on a corner to see if it rocks. Mine rocked quite a bit. The replacement part I got only rocked a little bit, maybe 0.5mm or less, something like that.
The test doesn't work on my 650's lower triple, since there are a couple of projections on the bottom that keep it from laying flat. In the future I guess I could use a piece of plexiglass & cut out a hole for the projections... not sure how true plexiglass is, though.
Last edit: 25 Aug 2013 10:02 by martin_csr.
  • kamakazie1000
25 Aug 2013 11:03
#602988
So lay it down flat, right side up, as if it we're sitting on top of the stem? The upper clamp is a new piece, broke some bolts off in the old one. Like I said I'll post some pictures later, but the way things line up I'm thinking the lower clamp or stem is definitely bent
kz1000 cafe project
  • kamakazie1000
28 Aug 2013 16:37
#603563
Finally took some pictures.
As you can see the forks don't line up at all the the top clamp. I have 2 top clamps, one that came with the old front end and a new one. Neither of them fit. Also when I took a closer look at the old fork tubes I noticed they we're bent. So, I'm thinking new lower clamp and steering stem?
kz1000 cafe project
  • MDawnz1
  • MDawnz1's Avatar
31 Aug 2013 02:17
#604096
Just 1 quick question.
Can you please pull off the top tree and put a straightedge on it?
The stem.
It looks bent in photo 4,Maybe just the lighting?
Its also past my bedtime .
1974 Z1a, still 903
