Queston on tapered neck bearing conversions
- nitrokeeb
21 Aug 2013 22:14 - 21 Aug 2013 22:19
Rebuilding my forks and thought it would be a good time to upgrade the steering stem bearings. I picked up an Allballs bearing kit (the kid in me snickers at the name) and it did not come with very detailed instructions.
The kit comes with two seals, each one a rubber ring bonded to a metal disk. The seal under the stock lower bearing was a two piece with a wavy metal disk and a thick rubber gasket. Is the new seal supposed to replace both peices?
I want to get it right as the lower bearing has to be pressed on over the seal.
New on the left, old on the right.
Attachment securedownload1.jpg not found
1978 KZ1000B LTD w/KZ900 engine
Last edit: 21 Aug 2013 22:19 by nitrokeeb. Reason: punctuation
- Motor Head
Re: Queston on tapered neck bearing conversions
22 Aug 2013 00:03
Yes it should replace both of those. There should be an upper and a lower bearing, and two seals in the kit. This should replace all the open ball bearings and seals that were factory.
22 Aug 2013 00:06Motor Head wrote: Yes it should replace both of those. There should be an upper and a lower bearing, and two seals in the kit. This should replace all the open ball bearings and seals that were factory.
+1
That's what I did when I replaced my bearings and the new tapered roller bearing work great. Ed
- ed spangler
- Tennessee Z
22 Aug 2013 07:22 - 22 Aug 2013 07:23650ed wrote:Motor Head wrote: Yes it should replace both of those. There should be an upper and a lower bearing, and two seals in the kit. This should replace all the open ball bearings and seals that were factory.
+1
Ditto!!, Me too, I replaced my original steering neck bearings /seals and I like the "AllBalls" :silly:
TennesseeZ Ed
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
Last edit: 22 Aug 2013 07:23 by ed spangler.
- nitrokeeb
22 Aug 2013 09:53
Thanks!
