how much air to put in shocks?
- chiaronate
17 Aug 2013 18:14
I did a search on here and didn't find anything about how much air to put in a 1982 1100 spectre suspension, front and rear. I ordered a repair manual that I should have in a few weeks. Is there a special air pump that is recommended? My bicycle pump doesn't seem to go far enough over the valves.
1982 Kawasaki KZ1100 Spectre
- rsrobboman
Re: how much air to put in shocks?
22 Aug 2013 11:16
Hello,
I have the same bike, (i,m in the uk )if i remember rightly its 2psi in front and back, lent my manual 2 a friend will check and get back to you when i get it back
- chiaronate
22 Aug 2013 11:42
Thanks, I just received a repair manual in the mail yesterday. It says 7.1-10 psi for front and 5.7-21 psi in back. I figure 10 in front may be good because I have a vetter fairing, and perhaps 15 in back as a compromise between comfort and in case I get an occasional passenger. I'll see how that amount of air feels and go from there.
- rsrobboman
22 Aug 2013 12:00
Glad your sorted out enjoy and be safe..
- chiaronate
22 Aug 2013 12:22
Thanks I'm also glad I could help, these forums can be pretty useful.
- chiaronate
22 Aug 2013 23:33
OK thanks I hadn't thought of inserting a signature, and also didn't know that the shocks can collapse and cause a tip over.
