brakes! help... i have an idea.
- sefbee
16 Aug 2013 04:33 - 16 Aug 2013 04:36
so, i had the idea to upgrade the front brake on the kz200 im building for my girlfriend...
i took a look at a brembo caliper i have, which is set aside for a yamaha xs500 project, and it looks like the offset of the rotor is almost exactly where it needs to be, if i can work out a simple bracket to attach the caliper to the fork.. ok. easy. can do..
the problem is that the caliper is a bit wider than the stock unit, and the back edge of it hits the spokes. if i can fit a larger diameter rotor, i think i can make it work, as the spokes narrow, and have more clearance, as you move the caliper further away from the axle.
it looks like my stock rotor is 10"
from what i have found online, a kz400 rotor appears to be 11"
can anyone tell me if the 4 bolt pattern for the kz400, where the rotor attaches to the hub is the same spacing as on the kz200? or maybe 650?
are there any other rotors which share this bolt pattern?
here's a few pics of the bike in question.
wheels are built from NOS 18x1.85 rims, stock hubs, and stainless spokes/nipples. tires are both 18x4.00 coker diamond classics, in case anyone was wondering.
thanks for the help in advance.
~s
~s
Last edit: 16 Aug 2013 04:36 by sefbee.
- Motor Head
Re: brakes! help... i have an idea.
16 Aug 2013 09:58
Not sure about the bolt pattern question. A lot of the hubs and wheels interchange without much effort. But when you get that all fitted you will have a very powerful front brake on the bike. At least if you stay with the small diameter master, it may have a progressive feel to it.
- wireman
16 Aug 2013 11:08
Pm Patton,he can probably find a list of bikes that list the same front hub or brake rotor.
That should get you started anyway.
- rixtrix
- Ride on !
17 Aug 2013 23:16
Sorry-don't have any help. Just wanted to say looks great so far !
1982 GPz1100
- wireman
17 Aug 2013 23:29
I wonder if it would be easier to adapt a caliper from 650/750/900/1000 on to there?
Theyre a dime a dozen,easy to find parts for.
- sefbee
18 Aug 2013 16:39
well.. it turns out that the rear caliper off a ducati monster fits very well, if i make a pretty simple aluminum bracket.
i'm using the master cyl and lever from a monster as well.
i'll post pics when finished.
thanks!
thanks!
- Boudewijn
- I like to tinker
06 Aug 2014 12:27
So how did it work out?
1983 KZ200
1993 Jawa 640
1989 Honda CB-1
Opinions are like assholes. Everybody's got one and everyone thinks everyone else's stinks.
1993 Jawa 640
1989 Honda CB-1
