16 inch wheel to and 18 inch spoke wheel, options?
  • 29 palms
  • 29 palms's Avatar Topic Author
15 Aug 2013 02:56
#601521
Ok, I have a 1981 KZ650 CSR. It has the aluminum rims with the spokes. The rear is a 16 inch rim. I'm looking to swap that out and find a 18 rear rim. I'd like to stay with spokes, and I'd like it to stay with the same aluminum style to match the front.
Option 1: Did any other Kawasaki bike have these style rims just in 18 inches, if so I would just re-spoke that to my hub.
-Option 2: two new set of rims that would be re-spoked to front and rear hubs. what would be a good light weight set of rims, I'd be looking for an aluminum(non chrome finish)48 spoke, 19 diameter in the front, 18 in the rear.
Re: 16 inch wheel to and 18 inch spoke wheel, options?
15 Aug 2013 09:00 - 15 Aug 2013 09:58
#601534
[strike]I don't think any KZ650 was originally equipped with aluminum rims on spoked wheels, so I suspect someone has already changed the rims.[/strike] See Martin's correction.
If you want to re-lace an 18" rim to your rear hub or re-lace both hubs with new rims & spokes these folks should be able to provide what you need. Ed
www.buchananspokes.net/
Last edit: 15 Aug 2013 09:58 by 650ed.
  • martin_csr
  • martin_csr's Avatar
15 Aug 2013 09:47
#601540
Aluminum rims were stock on the 1000 & 650 CSR models w spoked wheels. 19" Fr & 16" Rr.
15 Aug 2013 09:59
#601543
martin_csr wrote: Aluminum rims were stock on the 1000 & 650 CSR models w spoked wheels. 19" Fr & 16" Rr.
Thanks for the correction! I didn't know that. Ed
  • martin_csr
15 Aug 2013 10:21
#601555
The 650-CSRs are quite a bit different from the earlier 650s.
