Rims, sizes and interchangeable?
  • 10hi-f9s
  • 10hi-f9s's Avatar Topic Author
13 Aug 2013 19:35 - 13 Aug 2013 19:36
#601289
No eBay APP ID and/or Cert ID defined in Kunena configurationHi
I have a Z650-D2 on which I need a new rear rim, because the old one is in really bad condition.
I currently have the standard 16x3.0 (?) rim. I really want a bigger rim on the rear wheel (I'm thinking about the same size as the front wheel, which is 19"). So I've found this one which is 18x2.15 and is from a Z650-B
Will this work? And are the parts interchangeable, e.g. can I use the same disc brake and the same wheel assembly parts?
Thomas
Last edit: 13 Aug 2013 19:36 by 10hi-f9s.
Re: Rims, sizes and interchangeable?
13 Aug 2013 22:15
#601308
That wheel definitely is NOT from a Z650-B. All the Z650-B bikes came with wire wheels, not alloy. Ed
  • 10hi-f9s
15 Aug 2013 07:26
#601530
650ed wrote: That wheel definitely is NOT from a Z650-B. All the Z650-B bikes came with wire wheels, not alloy. Ed
Ok, but do you think it will fit? And can I use the rear wheel parts I already have with it?
15 Aug 2013 08:51
#601533
:laugh: :laugh: :laugh: :laugh:
If I knew that I would buy a lottery ticket! Without knowing what year & model motorcycle a wheel originally came on how can anyone know what it will fit and what parts are compatible with it? Ed
  • 10hi-f9s
16 Aug 2013 16:22
#601721
Ok, you make a good point ;)
The rear wheel of a C2 was 18" and alloy, right? If yes, how would that fit?'
16 Aug 2013 18:18
#601742
Yes, all the KZ650-C years had 18" alloy rear wheels. According to Kawasaki.com a number of the parts between the D2 and C models are the same, but there are some differences too. They show different part numbers for some parts including the swing arm, hub sleeve, hub bearing collar, 2 wheel bearings, etc. So you might need to do a bit of fiddling to make the wheel and rear brake work properly. Ed
