Any major differences between 81 and 82 kz750?
  • djturnz
  • djturnz's Avatar Topic Author
08 Aug 2013 22:26
#600504
I bought the TCbros forward control kit and it didn't fit just right. They say the test bike was an 81. Major issue was none of the bolts are long enough.
1982 KZ750 (4) LTD
  • martin_csr
  • martin_csr's Avatar
Re: Any major differences between 81 and 82 kz750?
09 Aug 2013 10:52
#600580
Assuming both models are the 750-4 Ltd, then they should be virtually identical. If the only problem is the bolt length, that should be easily solved. Just boldly go to a fastener shop.
