Can the locks be re-pinned?
- Shdwdrgn
07 Aug 2013 23:18
Having dabbled a bit in lockpicking, I have taken apart a few locks... I'm wondering if anyone here has pulled apart the various KZ locks and changed the pins so they all use a matching key?
I may not be in too bad of shape -- I have an ignition and gas tank that use the same key, but the seat lock is coming from a different bike. I couldn't turn up anything in the search, so I figured I would just ask.
1981 KZ1000-JK1
She's a beautiful mess, and I've made her all mine
- saxjonz
- KawboyZ
Re: Can the locks be re-pinned?
08 Aug 2013 01:45
The tank will open with any key. And yes, I know a locksmith that told me he could rekey the locks to the same key provided I had the pins. If I didn't might be more work I guess. Makes sense I guess.
79 LTD B3
- Motor Head
08 Aug 2013 09:13
You can grind the end of the tumbler pins off to make them level with the tumbler case when the key is inserted. Best after swapping them around to get 1 or 2 still sticking up slightly, then grinding.
- Shdwdrgn
08 Aug 2013 10:17
Thanks guys, but my question was aimed more at how much trouble is it to get the locks apart? I don't have one of the seat locks on hand yet, so I can only reference pictures online...and even when I do get one, I don't want to accidentally destroy it while trying to pull it apart.
1981 KZ1000-JK1
- Kidkawie
- I bleed premix
08 Aug 2013 10:42Motor Head wrote: You can grind the end of the tumbler pins off to make them level with the tumbler case when the key is inserted. Best after swapping them around to get 1 or 2 still sticking up slightly, then grinding.
+1
I saw a thread or video about that somewhere.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
