What length of chain is needed for a 1981 KZ750 E?
  • kinglouie321
  • kinglouie321's Avatar Topic Author
02 Aug 2013 19:51
#599580
Hey guys!
Not sure if this is the proper place for a chain question, but it will have to suffice. I'm a new rider on a '81 kz750, and I need a new chain. I'm aware that it is a size 530 chain, but was wondering if any of you knew what length(amount of links) I need. Thanks in anticipation!
Best
Ryan
Be water, my friend.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: What length of chain is needed for a 1981 KZ750 E?
02 Aug 2013 20:10
#599582
If you have a 1981 KZ750 E model, then it is an E2...which makes your chain a 630, not a 530 (if it has not been converted). So, if the sprockets are stock, and you are running a stock 630 chain, then you need a chain with 84 links. All this info came from the www.Kawasaki.com site. I also recommend that when you replace your chain, you also replace both sprockets.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
The following user(s) said Thank You: kinglouie321
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
02 Aug 2013 20:29
#599587
If it is a 630 You'll want to convert it to a 530. There's calculators for the sprocket conversion but keep in mind the sprockets will be larger which will call for a chain with more links.
Ask me how I know :angry:
Jim
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • kinglouie321
03 Aug 2013 04:03
#599644
I'm confused. I called a huge used parts motorcycle place, and the guy very confidently stated that my '81 would need a 530.....not sure how to confirm this...no idea if it was converted or not!
  • Nebr_Rex
  • Nebr_Rex's Avatar
03 Aug 2013 08:43
#599660
Just get the 530 chain and spockets, you need to change the all at the same time.
They wear together as a unit
If your parts source is reputable they can tell you the correct count on the number of links.
Leave that big and heavy 630 chain to the drag racers.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Nebr_Rex
  • Nebr_Rex's Avatar
03 Aug 2013 08:49
#599661
kinglouie321 wrote: I'm confused. I called a huge used parts motorcycle place, and the guy very confidently stated that my '81 would need a 530.....not sure how to confirm this...no idea if it was converted or not!
I hope your not thinking about getting a used chain.
Buy a new chain and sprockets.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • ThatGPzGuy
03 Aug 2013 09:31
#599663
Give the guys at Z1 a call. They can set you up.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • martin_csr
  • martin_csr's Avatar
03 Aug 2013 13:25 - 03 Aug 2013 13:27
#599693
ThatGPzGuy wrote: Give the guys at Z1 a call. They can set you up.
And Z1Enterprises has a chain conversion page, so you could check that.
Also, you can try the GearingCommander page to see if you might want to go with different sprockets - they happen to have a 750E loaded in the database.
I think the E came stock w 13T Fr & 33T Rr sprockets. My 81 650 has the same ones & it seems high revving to me, so I'd guess a 750-4 would be more so. To improve the fuel economy you could go w a 13/32 or 13/30 setup. Or if a 14T Fr sprocket will fit, a 14/33 & maybe a 14/32. It has been reported that a larger Fr sprocket won't fit, but I have never confirmed that. These are just a few possibilities. Someone else may have a better suggestion or two, though.
Last edit: 03 Aug 2013 13:27 by martin_csr.
  • kinglouie321
05 Aug 2013 03:25
#599902
Hey Guys!
Thanks for all the great feedback, it is much appreciated. I actually (and stupidly) found out about the chain size from looking under the seat. It IS a stock 630 chain, actually. I ended up buying a new o-ring chain, and cut it down to 84 links. Works beautifully!
