new shocks for 81´ KZ 1100
- trojan
26 Jul 2013 19:34
I´m thinking of installing 1998 zrx 1100 shocks to my KZ 1100. The zrx shocks are 20mm longer (KZ shocks are 340mm eye to eya and zrx, as far as I know are 360mm). How will this change the geometry/handling of the bike?
- MFolks
Re: new shocks for 81´ KZ 1100
26 Jul 2013 19:51
20mm is just over 3/4" of an inch, so I don't see much change to the handling, other than having greater ground clearance for possibly larger rear tire.
- upncummr
26 Jul 2013 20:32
Trojan:
I believe raising the rear of the bike decreases the rake and trail of the front forks and front wheel, respectively. That increases the steering quickness and decreases straight-line stability.
With the change you're proposing for the rear it's hard to tell whether you'd notice the related/inherent changes in the front geometry.
- rixtrix
- Ride on !
17 Aug 2013 23:24+1 Yup-what he said ! Will slightly put more weight on the front end too,however if the shocks have a lighter spring rate the longer shock length could be a wash.upncummr wrote: Trojan:
1982 GPz1100
