Sprocket won't fit rear hub
  • 3cav84a
  • 3cav84a's Avatar Topic Author
25 Jul 2013 02:34
#598169
G'day, I ordered a set of sprockets and a chain for my KZ750B twin and when they arrived I thought great today is the day I finally get to do the job. To my surprise the rear sprocket won't fit. The centre hole in the sprocket on my old one is 63-64mm and the center to center distance of the diagonally opposed bolt holes is 90mm. Ever since I had a new tyre put on the rim I have had a funny feeling that the whole rear hub/tyre set up is not original. I will take some photos later on today to put up here to see if anyone knows what sort of setup is on this bike.
Any ideas what this rear sprocket belongs to. It is 63.5mm hub 90mm bolt centre to bolt centre 38Teeth for a 530 chain, regards Neil
1977 KZ 1000 A1
  • martin_csr
  • martin_csr's Avatar
Re: Sprocket won't fit rear hub
25 Jul 2013 10:11
#598190
Photos might help.
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
25 Jul 2013 14:59
#598212
Stock would be an 80mm center hole, 6-bolt holes and 104mm center-to-center on opposing bolt holes.
How many bolt holes on your old ones?
Drum or disk on the back?
I looked up our references and there's nothing with the dimensions you mentioned - check the dimensions again. Also look for any markings on the sprocket. Most aftermarket sprocket suppliers stamp the sprocket series number and tooth count on each sprocket.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
  • 3cav84a
25 Jul 2013 22:50
#598293
G'day, so I took some photos of the strange rear wheel on this 1980 KZ750 twin. The hub has the two smallish sealed bearings fitted to the outer extremities of the hub, they look like rather small bearings for a 750 hub. the only thing I can find on the actual rim is a T and a M above it and somewhere else A199 in small numbers. The tyre fitted to the rim is a Battleaxe 130/90 - 16 m/c
Attachment IMG_0622.JPG not found
Attachment IMG_0624.JPG not found
1977 KZ 1000 A1
  • 3cav84a
25 Jul 2013 22:55
#598294
Here are a couple more pictures, I re measured the hub again and it is 64mm which converts to 2.5 inches and the center to center hole is 90mm. The sprocket is a 37 Tooth alloy/aluminium the only markings being 37 stamped into it.
1977 KZ 1000 A1
  • Jeff.Saunders
  • Vendor
  • Vendor
25 Jul 2013 23:04
#598296
That looks like a Morris Mag wheel.
2.5" center (63.5mm), 3.5" (89mm) center to center. Search for a PBI sprocket for the morris mag wheel.
Z1 Ent on Facebook,
The following user(s) said Thank You: 3cav84a
  • Dr. Gamma
  • Dr. Gamma's Avatar
25 Jul 2013 23:52
#598304
Its definitely a Morris Mag. The sprocket also has what they called a "cush drive" setup. Save those nylon spacers, and the inner collars. I don't think you will get they when you order a replacement sprocket.
Back in the day you could order your Morris Mag with non-cush drive, or with cush-drive sprockets. Make sure they know you need the cush-drive rear sprockets. I would like to find a spare set of those cush-drive nylon spacers and collars for my Morris Mag.
1986 RG500G 2 stroke terror.
  • 3cav84a
26 Jul 2013 03:38
#598333
Jeez this forum is great, thanks fellas I had never heard of a Morris mag wheel I will do a search of what is available here in Australia but I have a funny feeling I might have to either get one from the USA or get one made up. I'm definitely not going to get one made of the same material as the old one, 7500 miles and it's shagged one tooth missing and the others horribly worn, I don't think the PO was really keen on lubing the setup. Thanks once again, regards Neil
1977 KZ 1000 A1
  • Jeff.Saunders
  • Vendor
  • Vendor
26 Jul 2013 09:06
#598345
Morris Mags are one of the more desirable wheels from that period. There are road and race versions. The race versions are made of mag alloy and are VERY light - you can pick the wheels up with your little finger... Those are worth good money if in perfect condition. The street version was cast aluminum and much heavier.
The wheels themselves are interchangeable across bikes as different adapter plates for the brake and axle bolt to the hub of the wheel.
Aluminum rear sprocket is probably all you are going to find - and yes, it's likely you'll need to order from the USA to get these. PBI is one brand that still makes sprockets for the wheel.
You might also consider selling the wheels and buying KZ750 wheels - you will likely make some good money with those Morris Mags.
Z1 Ent on Facebook,
  • ed spangler
  • ed spangler's Avatar
  • Tennessee Z
26 Jul 2013 09:32
#598349
3cav84a wrote: G'day, I ordered a set of sprockets and a chain for my KZ750B twin and when they arrived I thought great today is the day I finally get to do the job. To my surprise the rear sprocket won't fit. The centre hole in the sprocket on my old one is 63-64mm and the center to center distance of the diagonally opposed bolt holes is 90mm. Ever since I had a new tyre put on the rim I have had a funny feeling that the whole rear hub/tyre set up is not original. I will take some photos later on today to put up here to see if anyone knows what sort of setup is on this bike.
Neil
Sent you a PM, let me know if it helps!?
TennesseeZ ED
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
26 Jul 2013 09:33
#598350
Jeff.Saunders wrote: Morris Mags are one of the more desirable wheels from that period. There are road and race versions. The race versions are made of mag alloy and are VERY light - you can pick the wheels up with your little finger... Those are worth good money if in perfect condition. .......
Was there a problem with the race versions cracking when they got old? I though I read someplace that the magnesium alloy didn't hold up over many years of use, but I could be thinking of some other wheel manufacturer. Ed
  • Jeff.Saunders
  • Vendor
  • Vendor
26 Jul 2013 09:42
#598354
With true Mag Alloy wheels, I don't think it's so much getting old as hitting bumps and pot-holes. I cracked an SMAC front wheel a few years ago hitting a curb - two of the six spokes had cracks all the way through... I was VERY lucky the wheel didn't collapse on me. They should not be used on the street - but many of us did...
Z1 Ent on Facebook,
