81' Kz750 spoked wheels
- KCCOer
24 Jul 2013 06:05
So this in my first Motorcycle and I'm looking to change up the look a bit, the bike is hard tailed and I'm wondering Is there a company that makes a set of spoked wheels for an '81 kz750, the thing is I'm look for them to be 19" & 21"..... Am I crazy or are they available? Are there any 60's-70's vintage wheels with the same bolt pattern? Thanks for any help!
This is my bike!
Attachment image.jpg not found
This is my bike!
Re: 81' Kz750 spoked wheels
24 Jul 2013 09:15
These folks will build whatever you want. You can contact them and ask for advice on where to start. Ed
www.buchananspokes.net
24 Jul 2013 09:53 - 24 Jul 2013 09:55
The best match for your bike probably would be the wheels from an 81-82 KZ1000-M CSR. Those models have 48-spokes w aluminum rims 19" Fr & 16" Rr and triple disk brakes. The Fr disks are unique to the bike. You could use the Fr wheel from an 81-82 650-CSR, but you'd need the disks from the Big CSR. I guess Buchanan's could lace up a larger rim at the rear?
Forks & brake caliper alignment. i don't know if the disks from the 1000-CSR will align properly w the 750-Ltd forks & calipers. My guess is that they will, but you may end up needing to get the forks & possibly the triple tree from the CSR in addition to the wheels.
Something you can do is to look in the KZR gallery for a 750-4 w wire spoked wheels. They all came stock w cast alloy wheels, so if you find one w spokers you might be able to find out what they did by searching their posts.
Last edit: 24 Jul 2013 09:55 by martin_csr.
- KCCOer
