KZ650 and KZ750 foot pegs mounts
  • 10hi-f9s
  • 10hi-f9s's Avatar Topic Author
21 Jul 2013 18:33
#597586
Hello
I'm new to this forum. I got it recommended on kz650.info
I am looking to do rearsets on my KZ650-D2 SR and I found a complete set on Fast from the Past for a KZ650, which doesn't seem to fit (my bike has the two bolt foot pegs), but I found this set for the KZ750, which looks like it might fit.
Now my question is, does the KZ650-D2 and the KZ750-E1 use the same two bolt system? Do you think it will fit? And did it have rear disc brakes?
I hope you can help :-)
  • martin_csr
  • martin_csr's Avatar
Re: KZ650 and KZ750 foot pegs mounts
21 Jul 2013 18:58 - 21 Jul 2013 18:59
#597587
The 750E has a Rr disk brake. For the footrests, you could get center-to-center bolt-hole measurements.
Last edit: 21 Jul 2013 18:59 by martin_csr.
21 Jul 2013 21:04 - 25 Jul 2013 23:00
#597612
x
Last edit: 25 Jul 2013 23:00 by 650ed.
  • david1050
  • david1050's Avatar
23 Jul 2013 12:27
#597876
I've been playing with a adapter idea to mount modern rearsets to older bikes. I can tell you that a 1979 KZ650C3 or C4 (I don't remember exactly) and the 1982 KZ750R1 can be interchanged. I added picures of my first protoype mounted on both frames.
David
2009 Vulcan 900 Custom
1975 Z1B 900 Mod/Resto project (91 KZ1000P forks and wheels)
1976 KZ900 Cafe bought to flip
1982 KZ750R1/GPZ750 project (95 ZX7 forks, 03 ZX636 swingarm)
  • 10hi-f9s
24 Jul 2013 17:32
#598099
Thanks for the replies!
martin_csr wrote: The 750E has a Rr disk brake. For the footrests, you could get center-to-center bolt-hole measurements.
Then I just need someone to measure their 750E :-)
david1050 wrote: I've been playing with a adapter idea to mount modern rearsets to older bikes. I can tell you that a 1979 KZ650C3 or C4 (I don't remember exactly) and the 1982 KZ750R1 can be interchanged. I added picures of my first protoype mounted on both frames.
I was hoping to find a kit that just fits, otherwise I'm thinking of buying this and getting a blacksmith to create a mounting plate. But that doesn't look half bad! :-)
  • Ederer
  • Ederer's Avatar
24 Jul 2013 18:02 - 24 Jul 2013 18:03
#598101
I was in the same boat as you and tried talking to fast from the past but they couldn't guaranty they would fit. I thought about purchasing one of the bracket arms from the kit to see if it would physically bolt up, I think you can order them separate. That would minimize the cost should they not work. I ended up buying their universal kit and making them work with a simple bracket - similar to the approach David took above.
I've changed things up a bit since these pics but you get the idea.
Last edit: 24 Jul 2013 18:03 by Ederer.
  • 10hi-f9s
25 Jul 2013 17:10
#598232
Ederer wrote: I was in the same boat as you and tried talking to fast from the past but they couldn't guaranty they would fit. I thought about purchasing one of the bracket arms from the kit to see if it would physically bolt up, I think you can order them separate. That would minimize the cost should they not work. I ended up buying their universal kit and making them work with a simple bracket - similar to the approach David took above.
That looks great! It looks fairly easy to mount, was all the necessary parts included? Also, which ones do you prefer, the curled ones or the straight?
Not a bad idea concerning the bracket arm, maybe I'll do that.
  • Ederer
  • Ederer's Avatar
25 Jul 2013 19:01 - 25 Jul 2013 21:21
#598258
I ordered the angled arms first, but have since purchased straight replacement arms as the angled ones weren't quite right for me.
As far as what comes in the kit, you will need to fabricate a shifter linkage. I cut down my existing shifter, and used my existing drum brake rod to make the linkage. On the brake side it really depends on what you have. I had a drum but converted to a mono-shock swingarm with a disk. That made it pretty simple as all I had to do is position the master cylinder on my bracket. To make things even more simple I went with an integral pressure switch/banjo bolt which eliminates the need for a conventional switch.
FFTP sells several linkage parts so it's pretty easy to piece something together if you don't want to cut up your existing parts.
Last edit: 25 Jul 2013 21:21 by Ederer.
  • 10hi-f9s
28 Jul 2013 17:35
#598735
Ederer wrote: I ordered the angled arms first, but have since purchased straight replacement arms as the angled ones weren't quite right for me.
Cool. Do you have a picture of solution on the shifter?
It's a bit hard to me to have in my head right, I think it will be easier once I have the parts :)
  • Ederer
  • Ederer's Avatar
06 Aug 2013 22:21
#600167
10hi-f9s wrote: Do you have a picture of solution on the shifter?
Yeah, sorry this took so long.
I simply cut the original shifter down and drilled a hole for the clevis pin. I used the existing drum brake rod, threaded the ends and bent it to fit. Works like a champ.
