Master Cylinder Disassemmbly
  • savedrider
  • savedrider's Avatar Topic Author
  • 1975 Z1-B 900
21 Jul 2013 02:31 - 21 Jul 2013 12:37
#597525
How in the world do you remove that circlip? I have circlip pliers, but they aren't long enough to get down in there. Doing a front brake overhaul (calipers and M/C), M/C seemed to be working good, but looked pretty crusty under the piston boot. I wanted to just disassemble and clean everything up for good measure. Or should I leave well enough alone?
Get right or get left! <*{{{><
Last edit: 21 Jul 2013 12:37 by savedrider.
  • Haybus
  • Haybus's Avatar
  • Big Al
Re: Master Cylinder Disassemmbly
21 Jul 2013 03:01
#597527
I ground a pair of long reach snap ring pliers, but if your ring has been in there for a while it might not come out that easily.
My original circlip was stuck pretty bad so I just bent it by pulling on one of the holes with a pick. Everything looked pretty good so I cleaned it up and put it all back together with a new clip. Made a sleeve to push it into the groove, also works to push in the boot retainer ring. Didn't fix my spongy lever, so I ordered a rebuild kit. That's when I ground the pliers. Sometimes you have to be willing to modify a perfectly good tool to get the job done.
Alan
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
21 Jul 2013 13:01 - 21 Jul 2013 13:08
#597556
Long-nose cir-clip pliers are available.
For example, here's Z1E listing:
Click > www.z1enterprises.com/ItemDetails.aspx?i...n+Pro&item=MP08-0279
As Haybus mentions, the old cir-clip may be so encrusted in position that it's destroyed during process of removal.
Repair kits may include a new cir-clip.
For example:
Click > www.z1enterprises.com/ItemDetails.aspx?i...22%29&item=43073-005
Good Fortune! :)
Last edit: 21 Jul 2013 13:08 by Patton.
  • savedrider
  • 1975 Z1-B 900
21 Jul 2013 21:07
#597613
Thanks guys, I've decided to leave well enough alone as the M/C seemed to be working well prior.
