leking brake caliper - piston stuck.
  • ggenovez
  • ggenovez's Avatar Topic Author
15 Jul 2013 23:27
#596684
Hi all,
I think I found why I can't bleed my brakes. looks like the rebuilt brake has a leak in it.
I tried getting the piston out by applying air to it but it is leaking too much.
Any ideas?
Thanks
George
KZ-1100 A1
  • Motor Head
  • Motor Head's Avatar
Re: leking brake caliper - piston stuck.
15 Jul 2013 23:37
#596686
A piece of wood block between the piston and caliper brake pad area to stop the piston when it comes out. Fill the caliper with some heavier oil, like clean motor oil, and more air volume, not really pressure. See if that will move it.
The following user(s) said Thank You: ggenovez
  • ggenovez
16 Jul 2013 09:54
#596725
Thanks motorhead. That did it.
Now to find another brake seal. There's a chunk missing
KZ-1100 A1
  • Motor Head
16 Jul 2013 09:57
#596726
