partial brakes
- ggenovez
partial brakes
13 Jul 2013 14:56
Hi all,
My front brakes where dragging so I replaced the seals on both calipers, and rebuilt the master.
I had to drain all the fluid out from the brake lines.
I have speed bleeders but I don't think they're working properly, I can see the fluid to back and forth.
I open the bleeders a quarter turn and press and hold. I've done several full reserves, but I still can't get a full lever.
Any ideas?
Thanks
Any ideas?
Thanks
KZ-1100 A1
- roy-b-boy-b
Re: partial brakes
13 Jul 2013 15:08
Squeeze the lever sever times and open the bleeder without letting off of the lever. Repeat a lot.
The following user(s) said Thank You: ggenovez
- ggenovez
- floivanus
Re: partial brakes
13 Jul 2013 15:48
For whatever reason i've never had good luck using the bleeder on these old kaws
What works for me is tapping with a wrench from bottom to top, hitting the calipers, lines, splitter etc, then slowly pulling the lever, repeat until you stop seeing bubbles come out the master
Past; 78 kz1000, 83 kz550
Andrew
Andrew
- ggenovez
- P21
Re: partial brakes
13 Jul 2013 17:15
open the bleeder alittle more
run a clear hose off bleeder and into a jar works great but you gotta open them bleeders more
Kawasaki KZ 1000 Police (2002) P21
- P21
Re: partial brakes
13 Jul 2013 17:17
if dual calipers do the left first then the right
- ggenovez
Re: partial brakes
13 Jul 2013 17:31
I have a long hose, just as long as the brake lines, clear, and I have pumped the brakes until the whole line was filled, and I still don't have a full lever.
I have noticed that brake fuild is leaking from the bleeder valve. Could that be my issue? any fix for that?
KZ-1100 A1
