new guy with a few rear swing arm and set up quest
- StreetfighterKz
Re: new guy with a few rear swing arm and set up quest
15 Jul 2013 13:22531blackbanshee wrote: i would remove the upper brace and weld an under brace on,add the dual shock brackets and it is a bolt in deal after the custom work that accepts a 99-07 busa rear wheel brake etc...
Find a '97-03 Gsxr600 arm. It should be virtually identical to the Busa's but lacks the top brace to begin with.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
- mrvoorhees
06 Aug 2013 23:46
Any pics of a bushing setup that's needed..... I got a swing arm free .......so I have the wheel, brakes and swing arm.........I'm going to tackle this over the winter..........
What about the drive sprocket and the off set... I was told I need a drive support kit because of the offset on the bussa wheel
- Powerstroke_fan
07 Aug 2013 08:25 - 07 Aug 2013 08:29mrvoorhees wrote: hell all i have a 1982 kz1000 that i would like to get stretched. i have a 2004 factory gsxr1300 rear wheel complete with sprocket, axle and rotor.
with this wheel and lets say a stock kz swing arm that has been extended whats my option for brakes. i would love to use the stock brakes because when i have the stock kz swing arm extended i can just have those mounting locations moved around and can also save money and time looking for parts.
if this wont work what will i need to look for . i have found a couple of gsxr swing armes already extended or even a after market swing army built for the kz
i think my biggest issue is the rotor on the busa wheel is not going to match up with the stock kz brake caliper
Those parts are not from a 2004 busa. Iam running a 99-03 busa rear wheel and brakes. The caliper do not look like mine. After 2003 they changed the rims a little and the brakes also. The rear rim almost looks like it could be from a 99 -03.
any help would be nice
Attachment swing.jpg not found
Attachment busa.jpg not found
Attachment ext.jpg not found
1977 KZ 1000 work in progress
Last edit: 07 Aug 2013 08:29 by Powerstroke_fan.
