KZ 440 rear rim question
- Granitestatekz
10 Jul 2013 21:54
will a 18" rear from from like a 750,900 or 1000 fit ? I have an 82' 440, this would be chain drive by the way with drum rear brake.
- Nebr_Rex
Re: KZ 440 rear rim question
11 Jul 2013 00:44
Chain offset is different from the 400/440 to 550cc and up bikes.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Cynjut
11 Jul 2013 12:52
... and the brake disc offset is different as well.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
11 Jul 2013 13:21
I think the closest match would be the wheel from a 440 standard B model. I have no idea if the drum assy, panel assy & coupling assy are interchangeable - the Ltd models have different part numbers than the B models, but it just may be that the B's are painted black?
- Granitestatekz
11 Jul 2013 23:16
Ok thank you guys. I was asking because to put an ice tire on it and 18 are easier to do and not sure if there is a 16 tire out there to stud up.
