dual front disc brakes
- gravyl17
09 Jul 2013 23:32
I need to replace the front brake pads on my 1978 kz 650. I got the bike from a guy who built it from several different models. Not sure what size pads to order. The bike has dual front disc brakes and is titled as a 1978 but not sure what to do. this is probably a newbie question but dont wanna buy pads that wont fit.
Re: dual front disc brakes
09 Jul 2013 23:41 - 09 Jul 2013 23:43
If you can, post a couple pics of the calipers. We might be able to identify them. Also, what is the VIN stamped in the steering neck? If it starts with "KZ650C" they may be the stock brakes. Ed
Last edit: 09 Jul 2013 23:43 by 650ed.
- gravyl17
10 Jul 2013 00:17
thanks ed ill go take the pics now and post asap
- gravyl17
10 Jul 2013 00:26
the vin says 650 B and hear are the pics........
Attachment IMG_0850.jpg not found
Attachment IMG_0849.jpg not found
- gravyl17
10 Jul 2013 00:30
This bike was built by a guy BoZ650 from this forum I found out. There are his build pics but didnt find any info on the brakes although I may have overlooked that information.....?
10 Jul 2013 00:49
Ok; it appears that the left caliper is the stock KZ650-B caliper that came on the bike. The right caliper looks like it is also a KZ650-B caliper (or possibly a Left Side KZ650-C caliper – see pic of mine) that has been turned upside down (notice the bleeder is facing down instead of up) and fitted to the right side of the forks. So – you should be ok if you buy 2 sets of pads that were made for the KZ650-B1 (the KZ650-C1 pads are the same). I would make sure you can return the pads if for some reason they are not correct. Ed
Attachment 00000_2013-07-09-3.jpg not found
- gravyl17
11 Jul 2013 06:18
Thanks for the help I'm gonna order the pads today......
